10-06-2018 13:07 - last edited on 11-17-2020 15:47 by MatthewFitbit
When I swipe over to Weather on my Charge 3, it never works and says to try syncing with my phone... That doesn't work either. Any insights?
07-03-2020 06:11
07-03-2020 06:11
Hi CathieW1,
If you use an Android phone, the issue could be the data usage setting. For weather to sync consistently on the Fitbit Charge 3, it appears you need to go to Settings/Data usage, scroll to Fitbit app, and uncheck the "Restrict background data." There may be a similar setting for iPhone, but I don't know. I consciously decided to check the "Restrict background data" on the Fitbit app because I get longer battery life on my phone that way. But when I had the setting unchecked, the weather on the C3 stayed current very well, not only for my current location but for 2 other locations. I hope this helps!
08-15-2020 04:43
08-15-2020 04:43
Cannot see weather on my fitbit charge 3 even after syncing with app.
Also giving incorrect floors climbed. Was working fine earlier.
Cannot see current heartbeat rate on the app.
08-16-2020 15:54
08-16-2020 15:54
08-22-2020 19:00
08-22-2020 19:00
Sean from London! Thank you!! Swipe left 3 times!! Why did it take me so long to hear that!!!
10-25-2020 16:13
10-25-2020 16:13
None of these work for me!!!
10-25-2020 19:45
10-25-2020 19:45
Mine is less than a year old. It’s already outdated. The weather works sporadically!! I believe they need to stop selling outdated watches at new watch prices. Or at least tell people they aren’t updating them anymore.
10-25-2020 19:47
10-25-2020 19:47
I’ve done this. It hasn’t helped me.
10-26-2020 05:21
10-26-2020 05:21
04-29-2021 12:15
04-29-2021 12:15
I have tried all the recommended fixes in this thread and none have worked.
