10-06-2018
13:07
15:47
10-06-2018
13:07
15:47
When I swipe over to Weather on my Charge 3, it never works and says to try syncing with my phone... That doesn't work either. Any insights?
11-19-2018 12:31
11-19-2018 12:31
11-19-2018 12:44
11-19-2018 12:44
11-19-2018 12:50 - last edited on 02-07-2020 15:37 by LiliyaFitbit
The weather information that I get now is still dated. Even after a sync,
the data states it’s up to an hour old.
11-19-2018 12:59
11-19-2018 12:59
11-19-2018 13:29
11-19-2018 13:29
ugh. i’ve done all the suggested steps.
weather finally showed last night, for maybe an hour after completing reset, update, sync. even then it was nearly an hour old.
and it’s gone again.
of course i bought from Target w a 30 day return policy and just passed that timeframe. so annoying. Fitbit needs to fix this or give us all refunds.
11-19-2018 14:07
11-19-2018 14:07
Yes. That’s the case for me too. Weather will only show up or update if I open the app on my phone and sync. Whereas steps can sync automatically throughout the day.
11-20-2018 05:47
11-20-2018 05:47
Hi! This seems to be a real hot topic! I think I have to synchronize and re-synch later as the weather will disappear after awhile.☺️ I’ve gotten A LOT of responses about weather not appearing on (our) Charge 3’s!
11-20-2018 06:27
11-20-2018 06:27
11-20-2018 07:47
11-20-2018 07:47
I've tried using the Weather app, but after following all the recommended steps, the app will not display my current location nor display city names when I try to add them to the app in settings. I've deleted the app from my iphone and reinstalled it. That did not help. Location services are enabled on my phone and the fitbit app is set to always allow location services. What other steps can I possibly take to get the weather app to work on my Charge 3? All other enabled apps work fine. Is my Charge 3 defective in some way?
11-20-2018 08:54
11-20-2018 08:54
11-20-2018 09:09
11-20-2018 09:09
11-20-2018 13:28
11-20-2018 13:28
Hi Jeff2922- no... you are part of the “crowd “ that has trouble getting the weather on your Charge 3. Mine shows (I think) Centigrade for the brief time after I synch my C3. It tells me the temp is 12*!☺️🤣 I think we can ALL look forward to this ‘bug’ being fixed in the future...
11-20-2018 13:40
11-20-2018 13:40
11-20-2018 19:39
11-20-2018 19:39
11-23-2018 10:51
11-23-2018 10:51
Hi everyone! If you've followed the tips and recommendations I've share here, but the inconvenience persists, I'd recommend trying a Factory reset on your Fitbit Charge 3.
On your device, open the Settings app > About > Factory Reset or Clear User Data.
After doing the factory reset and the issue persist, please let me know. I'll be around!
11-23-2018 19:21
11-23-2018 19:21
11-23-2018 19:37
11-23-2018 19:37
@SantiR Your response is detailed in the documentation. Thanks for sharing. However, my device has a similar but not the same issue which I’m hopeful you may have a fix for.
I have All-Day sync enabled. At no time when I go into my weather app on the Charge 3 is the weather synced. A message is displayed saying I must synch. If I wait for a few seconds, after the delay the weather them comes up.
As a test. I have just now down a hard ‘sync now’ action on the iPhone App, waited for that to complete, have it 20 second and them went into the Charge 3 to load the weather app. The exact same “you need to synch’ message is displayed, you wait a few seconds, and then the weather comes up.
Is that hat as programmed or is it a bug?
11-26-2018 07:03
11-26-2018 07:03
I read and followed the directions for enabling GPS on my phone (I already had) and syncing my new charge 3. It still will not show weather and tells me to sync to my phone, which I have done at least 10 times. Help!
11-26-2018 08:32
11-26-2018 08:32
11-26-2018 08:32
11-26-2018 08:32
I've given up on the weather app. If I have to sync it with my phone every time I want to see the weather, I'll just use the weather app on my phone period. I'm also having an issue with my fitbit and stairs. It had me doing 13 flights of stairs the other day, when all I did was ride the escalator at the mall up and down once.
