10-06-2018
13:07
15:47
10-06-2018
13:07
15:47
When I swipe over to Weather on my Charge 3, it never works and says to try syncing with my phone... That doesn't work either. Any insights?
11-26-2018 12:17
11-26-2018 12:17
Sadly, that approach has not worked for me. I think we are waiting for a software update from Fitbit with the weather app developer, to properly resolve this ‘bug’ of variable sync with the weather app.
Thank you all for your suggestions.
Best Answer11-26-2018 12:44
11-26-2018 12:44
Hi Marre,
I'm reporting back again that the action you proposed here actually made things worse. Clearing User Data on my C3 has made it so I can no longer use "All Day Sync" in the app on my iPhone. It seems to be connecting to Bluetooth, but "All Day Sync" just gets a pinwheel spinning indefinitely now.
Because of this and the many other issues noted in this thread, I find it problematic that the conversation is marked as "Solved." I'm at the point of requesting a refund for my C3 due to the Weather app not working. Marking the convo "Solved" is misleading.
Thanks!
Damien
11-26-2018 18:28
11-26-2018 18:28
I have Locations on, and still no joy for weather. Initially no local area but it did work for 2 cities I added!! Now 3 weeks later weather simply says to sync the device and my phone etc etc, which I do regularly, but does not help at all. I’m in Adelaide Australia. Hope you have some ideas for me!!!
Best Answer11-26-2018 20:23
11-26-2018 20:23
Best Answer11-26-2018 21:30
11-26-2018 21:30
I just got the charge 3 and followed your advice found the weather setting it works thanks
11-26-2018 22:50
11-26-2018 22:50
I've tried the steps listed and still it hasnt worked for me. sad
Best Answer11-27-2018 15:24
11-27-2018 15:24
I turned on location services on my iPhone, set AccuWeather to always on, since my Fitbit charge 3 and I still don't see the Weather. Suggestions
Best Answer11-27-2018 17:14
11-27-2018 17:14
11-27-2018 17:24
11-27-2018 17:24
11-27-2018 18:34
11-27-2018 18:34
Best Answer11-28-2018 05:46
11-28-2018 05:46
If I have to sync the weather with my phone EVERY time then I’ll just look at the weather on my phone instead. It’s a wasted feature in my book.
11-29-2018 03:40
11-29-2018 03:40
Hi everyone! I really appreciate you've taken the time to try and follow the recommendations along this thread. I've been reporting this situation as it caught to my attention that all of you are on iOS devices, so I'd appreciate if you can provide me with the following information:
- What iPhone/iPad you have
- What OS is your iOS running
- Version of the Fitbit app
- Firmware Version of your Charge 3
Looking forward to hearing from you!
Best Answer11-29-2018 05:49
11-29-2018 05:49
Best Answer11-29-2018 07:48 - last edited on 02-07-2020 15:37 by LiliyaFitbit
Apple iPhone 7 Plus
IOS 12.1
Fitbit Version 2.83
Charge 3 Version 20001.44.33
Best Answer11-29-2018 08:29
11-29-2018 08:29
Thanks @Calehu and @BEC29! To see which version of the Fitbit app is installed on your device:
Let's see what the others say about what I asked!
Best Answer11-29-2018 08:31
11-29-2018 08:31
Thanks for that - my app version is Fitbit 2.83(804)
08:36
08:44
11-29-2018
08:36
08:44
For what it's worth, weather works on my Charge 3. Sometimes it takes 30-45 seconds for it to show up on the tracker. It tells me below the temperature how long ago it was I synced so that way I know how old that weather reading is.
iPhone X running iOS 12.1
Fitbit Charge 3 Version 20001.44.33
Running Fitbit 2.83 (804)
@Babydottie13 To be fair, your Fitbit is taking the weather data provided by your phone and populating it on your tracker. If you don't sync at least periodically during the day, you're going to be provided with inaccurate weather data.
Best Answer11-29-2018 09:03 - last edited on 02-07-2020 15:37 by LiliyaFitbit
2.83 (804)
Best Answer11-29-2018 09:20
11-29-2018 09:20
Best Answer11-29-2018 09:38
11-29-2018 09:38
Hi! I’m not very tech savvy, but here goes...
i have an iPhone8
i think the OS is 10(?)
i update my app so I’m probably current
i just got my Charge 3, so it’s probably the most recent firmware.
You ALL are wonderful! The Fitbit community is the BEST!❤️
