10-06-2018
13:07
15:47
10-06-2018
13:07
15:47
When I swipe over to Weather on my Charge 3, it never works and says to try syncing with my phone... That doesn't work either. Any insights?
11-29-2018 10:32
11-29-2018 10:32
11-29-2018 13:44
11-29-2018 13:44
11-30-2018 10:23
11-30-2018 10:23
It only seems to work when you sync up and have the weather app open on the fitbit. Kind of dumb
11-30-2018 12:37
11-30-2018 12:37
11-30-2018
13:08
06:43
AlejandraFitbit
11-30-2018
13:08
06:43
AlejandraFitbit
What is interesting is it will work for the rest of the day. Then requires
you to do the same thing the next day
They need better testers
Moderator edit: removed personal info
11-30-2018 13:24 - last edited on 02-07-2020 15:36 by LiliyaFitbit
I wish that we could delete the weather app, but no.
11-30-2018 13:34
11-30-2018 13:34
Great idea, I’d love it if it was reliable
12-02-2018 00:17
12-02-2018 00:17
I’ve done this, but still no weather. And I can’t add another city. I put the name in the search box, but no option comes up to add it.
12-02-2018 05:06
12-02-2018 05:06
12-02-2018 18:25
12-02-2018 18:25
It did not work.
12-03-2018 15:04
12-03-2018 15:04
I'm experiencing these problems with the following specs:
- iPhone 5c
- iOS 10.3.3
- Fitbit 2.83 (804)
- 20001.44.33
12-05-2018 06:45
12-05-2018 06:45
Hey all, I hope you are doing fine.
I appreciate all the efforts in trying to fix the weather issue you all are experiencing. If the weather for your current location doesn’t appear, check that you turned on location services for the Fitbit app. For instructions, see How do I allow the Fitbit app to use my phone's GPS?. If you change locations, sync your device to see your new location in the Weather app.
I hope this helps, let me know the outcome.
12-05-2018 07:43
12-05-2018 07:43
I am experiencing these issues with both location sharing always on and background app refresh enabled. Perhaps a clue to why this is not working is in the Location Services menu where the indicator arrow is grey (not recently accesses) and not purple (recently accessed).
12-05-2018 08:56
12-05-2018 08:56
12-05-2018 09:21
12-05-2018 09:21
Hi! Base Runner had a great idea! Have a square on the dashboard for weather. That would solve everyone’s difficulties getting weather on their Fitbit!☺️👍
12-06-2018 00:38
12-06-2018 00:38
I recently purchased a charge 3 and am experiencing the same issue. The only time I can get the weather to update, even after syncing, is to reboot the device.
12-06-2018 01:35
12-06-2018 01:35
Azapia83- that seems to be the universal solution . I re-synch in order to get the weather. There’s been such a response about this! Just re-synch, which you would probably do anyway...☺️ Have a good week!
12-06-2018 01:50
12-06-2018 01:50
12-06-2018 03:30
12-06-2018 03:30
My mistake. I apologize. I synced my phone / the app this morning and did NOT get the weather!😳 So this problem seems to be capricious as well. I just go to the Weather Channel app now. At least if I get caught in a rainstorm my Charge 3 will be ok if it gets wet!!🤣 I hope you have a good week...
12-06-2018 08:33
12-06-2018 08:33
