10-06-2018
05:16
15:47
10-06-2018
05:16
15:47
Anyone else having this issue? After a 3 mile hike up a mountain, I look down and see I have 7500 steps, 24 floors, and zero active minutes.
11-19-2018 11:15
11-19-2018 11:15
Hiya.
Ive noticed that my active minutes on my charge 3 are also not working,
i played 70 minutes of hockey and my heart rate was up but no active minutes recorded at all.
Any suggestions please
12-01-2018 18:57
12-01-2018 18:57
Hi Santi,
could you let us know if fitbit is going to address the issue? It’s a glitch or something. I just got my charge 3, I had a charge HR prior. I feel like I have to go back to the HR as the charge 3 will not record any active minutes. It erroneously counts the number of flights of stairs as well, but at least it’s counting some. My active minutes have been zero since I started using this a week ago. I have hit all my goals for a very long time and now I have an entire week of not hitting all of my goals. Very disappointing.
12-03-2018 15:16
12-03-2018 15:16
Hi
I'm having the same issue.
My activity level has not changed over the last week however I have 0 active minutes this week and last week whereas before I was always having active minutes recorded of at least 45 minutes a day.
especially at weekends when I run around after my little boy a lot but this weekend 0 active minutes which is so strange considering my activity level is the same and a bit more on the weekend.
previously even things like doing housework clocked up active minutes and again after vigorously cleaning the kitchen this evening for 30 mins there was nothing recorded on my charge 3 for active minutes!
12-03-2018 19:07
12-03-2018 19:07
My problem is opposite of yours. I went swimming Saturday and Sunday, 1 full hour non-stop freestyle. I did the swim app so that it is timed for me to swim one hour. Both days it registered as exercise, but was not added to active minutes. Next weekend I am going to just let the Charge 3 autorecognize my swim just to see what registers where.
12-19-2018 11:51
12-19-2018 11:51
I'm on a beta blocker for blood pressure which keeps my heart rate down. The charge 3 is penalizing me for the medication. The charge 2 was much more accurate. Thinking about sending the 3 back and going back to the charge 2.
12-19-2018 14:18
12-19-2018 14:18
Mine is doing that if I actually go into the exercise and start it. The right number of days show if the charge 3 works out that I am doing the exercise itself. It shows as active minutes but doesn't show as the right number of days. The only way I could fix it was to go to the dashboard of my pc and then log the activity again.
12-22-2018 02:35
12-22-2018 02:35
When will Fitbit address the issue of the Charge 3 not tracking active minutes?
12-22-2018 05:52 - last edited on 02-07-2020 16:16 by LiliyaFitbit
Good question.
Sent from my iPad
12-25-2018 08:45
12-25-2018 08:45
I’ve had my Charge 3 for a couple of weeks now and it would always automatically record my activity as it’s supposed to. Suddenly, yesterday, I taught my Bootcamp class in which my heart rate was at or above fat-burning for 20+ minutes and it still sus 0 active minutes.
Why is that and how can I fix it? I even make sure to wear the watch snug as instructed. And, as I mentioned, this problem hadn’t been happening until now. Coincidentally, it was after the most recent update.
01-01-2019 14:32
01-01-2019 14:32
Santi - This doesn't help at all, unfortunately. We are all having the same problem with our Fitbit not actually registering our active minutes. We are all obviously aware of how it is supposed to work, as the majority of us have "upgraded" (possibly downgraded) to a FitBit Charge 3 from another FitBit device...and we are used to things working the way they should and have been advertised.
So the question isn't "how do active minutes work", it is "why aren't the active minutes working".
I have only just recently purchased the FitBit 3 a few days ago, "upgraded" from the Alta. I am profoundly disappointed that this question feed started months ago and the issue is still not fixed.
Do do I return the Charge 3 and go back to my old Alta?
01-01-2019 22:31 - edited 01-01-2019 22:35
So last week I had to do a firmware update. Said it would take a half hour but it took more than one hour. I went swimming on Sunday. I used the swim app and chose 60 minutes. It seems like the number of lengths was accurate and I did get over 60 minutes added to the “active minutes”. It showed I burned over 200 calories. Before the firmware update, it would show that I was burning only 50 calories. It seems to be working now. Plus I like that I have the Charge 2 face now!
01-08-2019 11:16
01-08-2019 11:16
The mystery of the missing active minutes , a new volume of the "yet another issue with the Charge 3 series"!!
I have the same issue! It recognised my active minutes earlier today, but this afternoon they have vanished!! I have done very little this afternoon so i don't believe its an issue with my heart rate leveling out, I've rebooted, restarted the app and no good?? I have also lost some of my historic activity data??
Any sign of a fix for this? This is not a cheep watch, I would expect it to be working fully? And not making allowences for its operating issues??.
01-08-2019 11:26
01-08-2019 11:26
Good luck... I did not have any luck with Fitbit finding a solution, the scripted answers did not sit well with me. I have the regular Fitbit and the Hr 2, they both work fine with the active minutes. Fitbit is in denial about the 3 logging active minutes.
01-08-2019 13:49 - last edited on 02-07-2020 16:17 by LiliyaFitbit
This might explain why they are already being marked down at Costco.
Sent from my iPad
01-08-2019 14:54
01-08-2019 14:54
Back in December I was told an Engineer was going to take a look. I’m still waiting. I am going to return my Fitbit to Kohl’s.
01-09-2019 17:21
01-09-2019 17:21
My charge 3 won’t track any active minutes. I take a Pilates class with my sister and her charge 2 records her active minutes during class and her workout. My charge 3 still reads 0 active minutes at the end of the same class. THIS IS OBVIOUSLY A PROBLEM WITH THE CHARGE 3. Very disappointing.
01-09-2019 20:45
01-09-2019 20:45
Fitbit definitely needs to fix this. It’s is unfair for those of us who want to see how we are doing. I should get credit for all the minutes I spent weight training and spinning, not some of the minutes. If you can’t credit us for what we actually do you should let us be able to edit it. The other day I went on a walk and got full credit yet today I weight trained and got on my bike for a total of 28 minutes and I only got credit for 18 minutes of it all. Regardless of my heart rate I should get credit for not sitting on my **ahem**.
01-11-2019 19:03
01-11-2019 19:03
I ran for close to an hour and my heart rate was well over 140 average. My active minute was zero. There is a clearly a problem with the device or the software
01-15-2019 14:15
01-15-2019 14:15
Imagine my disappointment to join so many others having issues with zero Active minutes. I have a very active job and typically had 200-400 active minutes with my Charge 2. I just started with the 3 this week, yesterday I had 0 minutes and today a whopping 27.
What gives Fitbit? My job hasn't changed one iota. I'm still walking briskly, bending, reaching, climbing ladders, and lifting. The inability to count activity minutes is frustrating and demoralizing.
01-18-2019 16:31
01-18-2019 16:31
I loved my charge 2 but my new charge 3 is not recording active minutes
