04-28-2021
06:02
09:27
WilsonFitbit
04-28-2021
06:02
09:27
WilsonFitbit
I woke up today and my watch and app both say I moved 53,000 steps overnight. It also shows I was sleeping at the time. How can I correct my steps for today? I have tried resetting and checked my timezone, but it hasn't helped.
I have also noticed lines showing up on my watch screen. Is there any way to fix that?
Thanks!
04-28-2021 09:29
04-28-2021 09:29
Hello @Piratelvr3. Welcome to the community forums!
Thank you for the information and for the troubleshooting steps you've followed prior to posting.I suggest you to please confirm that MobileTrack isn't enabled. MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available. But there was a fan or anything buzzing nearby, or if your phone was vibrating during that time, that might have caused you to receive incorrect steps tracked.
If this is the case, I'd suggest you to remove this feature by following the steps described in this help article and monitor your tracker's behavior to see if this has any relationship with the high amount of steps. If that doesn't change after you remove this, please let me know.
For screen inconveniences, I recommend visiting this thread for tips and suggestions.
I look forward to your response.
Best Answer04-28-2021 10:58
04-28-2021 10:58
Thanks for your reply. I have never had an issue with the mobile track before. I have disabled it, but it also shows the same step count on my watch. So I'm guessing that's not the issue.
I tried to do the long reset on my watch in regards to the lines and it didn't do anything.
Best Answer04-29-2021 04:25
04-29-2021 04:25
@Piratelvr3 Thank you very much for your reply.
Since the inconveniences have persisted, my best recommendation is that you please reach out to our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
Please make sure to explain the situation and mention the troubleshooting steps you've followed, this way they can assist you from there.
See you around.
