08-16-2019
10:37
10:46
08-16-2019
10:37
10:46
My charge 3 band latch got stuck while I was trying to change out the bands too my accessory bands and I haven’t been able to find any way to get it unstuck. I’ve tried everything I could think to and still got no give. It seems to just be jammed with no way to be released. This forces the band to be pushed out even if it is pushed all the way on till it can’t be any more
08-17-2019 10:47 - edited 08-17-2019 10:47
Welcome to the Community Forums @Zombiegamer935. Thanks for the steps you tried so far in order to remove your bands.
Fitbit Charge 3 have 2 detachable wristbands (top and bottom) that you can replace with accessory bands sold separately. To remove and replace the bands on both sides:
Give this a go and let me know the outcome, I'll be around.
08-20-2019 00:25
08-20-2019 00:25
I looked at this before hand and it didn’t seem to help. I had to de jam it with a flat piece of metal and I have to get something to make sure it can’t be something lodged inside or anything like that
08-20-2019 10:37
08-20-2019 10:37
Hello there @Zombiegamer935, thanks for getting back.
As per the description of your post, I'm not quite sure if you did manage to remove the bands? Did you put the new ones already?
I'm looking forward to your response.
12-06-2019 06:48
12-06-2019 06:48
I have a similar problem. Band was hard to remove and once it was off the latch on one side is stuck in depressed position. Would WD40 help?
05-01-2020 08:30
05-01-2020 08:30
This happened to my husband because he didn't clean the band regularly and it built up a disgusting layer of sweat/oil/skin. I forced one side off and cleaned it, but the band piece wouldn't stay on when reattached. I couldn't get the other band off without excessive force and gave up because I thought I'd broken the other side by forcing it. I bought him a new Fitbit and then decided it didn't matter if I forced the other band off the "old" Fitbit as well. I cleaned all the junk off both ends and then decided "the heck with it" and used soap, water and a bristle brush cleaner to do a deeper clean. After I dried it, both bands were reattached and stayed just fine. So now we have an extra FitBit for backup.
07-17-2020 09:02
07-17-2020 09:02
I had the same issue. One side wouldnt release the wrist band. I forced it down and it stayed depressed. The band had been clogged with various gunk. My solution was to soaked it in peroxide which did the trick. Was able to work the button out. No issues since.
07-24-2020 09:20
07-24-2020 09:20
I play a lot of tennis and my band broke while playing. I could not budge the strap connection. Using peroxide seemed to help a good bit. I still had to do some prying to get one side off and I think I broke a piece off of the Fitbit side. I don't think this was the best design. An earlier model had a metal release on the strap side I think. I am sort of surprised how gunked up the Fitbit strap connection was. I guess I missed the memo on cleaning, especially when using it with activities where extreme wrist movement is involved. Time to try another brand because by the time I purchase a new band the Fitbit will die.
02-10-2021 11:37
02-10-2021 11:37
Did you just soak the whole fitbit in peroxide? didn't it ruin anything else? I am curious because mine just went off warranty and the band broke. I have the spare band but can't get the old one off on one side.
02-10-2021
12:29
12:08
AlvaroFitbit
02-10-2021
12:29
12:08
AlvaroFitbit
I did not soak it in peroxide but that sounds like a good idea. I got one
side off and did get to see how disgustingly dirty it gets at the
connection site. The other end simply broke while pulling to get it off.
Try the peroxide with a Q-tip or soaking just the connection area.
Definitely not the electronic sensor area.
Moderator Edit: Personal info removed
02-10-2021 15:31
02-10-2021 15:31
My latch was stuck 'down' also. I got a small dish of hydrogen peroxide and dipped the stuck end in it just shy of the sensors. It bubbled like mad and I used an old toothbrush to scrub it. Then rinsed with water and repeated a couple of times. It took about 5 minutes to slowly come to the 'up' position. I did a few more rounds for good luck and voila! Good as new, except the small wing I broke off on the push latch getting the band off initially. Minor.
I sweat a lot and was cutting firewood and brush for fire clearance and must have totally gunked it up.
What started the process was when the buckle broke off from wear. I have used the FitBit daily for a year. Love it.
02-10-2021 17:13
02-10-2021 17:13
08-29-2021 19:33
08-29-2021 19:33
Sadly Fitbit support stated the band jamming happens often and there is nothing to do about it but buy a nee one. I love the Fitbit product but since they keep breaking shortly after the 12 month warranty is over I am now searching for alternatives.
08-30-2021
04:21
07:21
08-30-2021
04:21
07:21
Hello everyone. @Lafmia Welcome to the community forums.
Thank you very much for loving our Fitbit products and for taking the time to provide your feedback. Please note that any feedback posted in the forums is always welcome as it helps to improve our products, services and overall environment.
On a side note, I appreciate your understanding but I'd like to let you know that replacement devices are provided for products within the warranty period. If your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
08-30-2021 05:00
08-30-2021 05:00
I am aware of Fitbit 12 month warranty because at least four of my past Fitbit’s have broken after only 13-18 months.. Watches that cost $150-$200 really should last longer or the warranty should last longer.
08-30-2021
06:15
07:18
08-30-2021
06:15
07:18
@Lafmia Thank you for your reply.
I understand how you are feeling and I appreciate the feedback provided. If you still have any additional questions or comments, please note that you can also mention these to our Support Team and they will be glad to provide information and assistance.
On a side note, this thread is now closed and if you have any other questions, please post them in a new thread.
