08-19-2019
20:12
10:43
08-19-2019
20:12
10:43
My charge 3 belt was broken, and still within one year warranty. Therefore, I contacted support and get the replaced belt. However, when I tried to install new the belt, I found that one side of the fitbit is easy to take off from charge3, but the other side cannot take off, even I use my fingers, and also try a pen to push the button, but cannot take if off. The button just cannot press in. I even tried press the button and twisted the belt, still cannot take the belt off.
Two days ago, I contacted the fitbit support with an image to explain. An agent called Alvin quickly responded me ( I appreciate it) and asked for a video to prove myself. Then I sent a video to support. But I did not get any reply. This morning I reminded the support team again, but still no any response. I believe that fitbit support just intentionally ignore me.
Can anybody help me? Thanks in advance!
08-20-2019 08:02 - edited 08-20-2019 08:05
Welcome to the Community Forums @hahamm. Thanks for the steps you tried so far in order to remove your bands.
Also, thanks for contacting our Support Team prior to contacting us. I've check with our team and it seems that they replied to you after you posted here.
Please make sure to check your inbox.
Fitbit Charge 3 have 2 detachable wristbands (top and bottom) that you can replace with accessory bands sold separately. To remove and replace the bands on both sides:
Give this a go and let me know the outcome, I'll be around.
Best Answer09-17-2019 04:38 - edited 09-19-2019 06:38
Hello,
Update to my post below - I received replacement straps under warranty and to my surprise they worked!! - so in my case it was worn straps rather than worn pebble latch
I have exactly the same problem in that the wristband latch on one side of the fitbit is clearly stuck in one position (depressed in) and will not move thus the wristband on that side comes off very easy - especially during heavy excercise or swimming. Have almost lost the fitbit a couple of tmes now as do not realise it has fallen off and have to search for it
I have reported this to helpdesk as my charge 3 is still in warranty - sent in pictures etc and helpdesk have quickly despatched a replacement band.
I fear this will not solve the issue - it is clearly the latch that is stuck and will not move.
I will wait for the new wristband to arrive and try but lets see.......
otherwise i will re-open the case and send in further evidence
10-27-2019 20:43
10-27-2019 20:43
I have exactly same problem. What can I do?
10-28-2019 04:21
10-28-2019 04:21
Best Answer10-28-2019 05:56
10-28-2019 05:56
10-28-2019 06:47
10-28-2019 06:47
10-28-2019 07:01
10-28-2019 07:01
Best Answer10-28-2019 07:32
10-28-2019 07:32
Best Answer12-28-2019 08:59
12-28-2019 08:59
I didn’t realize my band was under warranty still so I bought a new one. I have the same problem with one button stuck down and it won’t hold the new band on
12-28-2019 09:35
12-28-2019 09:35
Best Answer12-29-2019 21:23
12-29-2019 21:23
Best Answer02-25-2020 16:39
02-25-2020 16:39
Had two problems a lot of people having. The longer band (with holes) came off but then it would not stay on once reattached. The other shorter band (with buckle) would not come off despite pressing it extremely hard but eventually did using a popsicle stick to press latch but then button was stuck in down position. To make a long story short I used alcohol with a kids coloring paint brush to dab the latch areas again and again and again while blowing on the latch occasionally to clean it. The longer band latch freed up quickly springing back to the original position and the new strap then attached without an issue. The buckle band would not come back up and I used a small screw driver to pry the button up by its edges while continuoulsy soaking it with alcohol and eventually it loosened up. Be careful with prying, the edge of the button breaks off easy as I sadly found out but does not appear to affect the attachment. My assumption is dirt and sweat makes a pretty good glue and most be dissolved before buttons work. Next time will first dab with alcohol to break bond and then press button. Good luck. Oh, and FITBIT, poor design.
02-25-2020 16:52
02-25-2020 16:52
Forgot to mention the reason I had to replace the bands initially was because the buckle broke off from the smaller band. In addition, I did call FITBIT to ask for help with the band removal issue but they were of little help. I mean why send a video of your issue. Pressing a button down is not rocket science. It either works or not. The device was 30 days out of warranty (1year) so they were willing to give me 25 percent off towards a new purchase. Come on. A broken buckle forces you to replace a $125 device? Once this Charge3 bites the dust, it will be no more FITBITs for me.
Best Answer02-25-2020 22:01
02-25-2020 22:01
Best Answer02-26-2020 06:02
02-26-2020 06:02
02-26-2020 06:31
02-26-2020 06:31
Have had a few thoughts of this issue since yesterday. Next time I will try vinegar which is a mild acid to help clean/dissolve the built up sweat and dust. Might work better than alcohol. Also next time, will use a very tiny drop of WD40 (the kind that is safe with plastics) to lubricate the latch/button mechanism once cleaned. This may allow it to go up and down easier. Just some ideas maybe someone can experiment who is now having the issue.
03-02-2020 09:40
03-02-2020 09:40
I was having the same issue with my husband’s FitBit charge 3... he has has his six months and wanted a leather type strap but in the time he has had the tracker he has done loads of sweaty exercise, and the original strap just wouldn’t budge.
I tried a bit of vinegar and did manage to get the straps off and cleaned it up. The new straps went onto the now clean tracker beautifully and are staying put nicely 👍
And my efforts were appreciated as he says his new strap is so much more comfortable.
04-27-2020 17:08
04-27-2020 17:08
The information posted by WXWIZ is what finally enabled me to fix my Charge 3 band problem (buttons both stuck in). I used my Charge 3 daily for 9 months with no trouble. Then I broke my original band and bought a replacement from Walmart. It would not stay on. I read many posts about this issue but none helped me until I got to WXYIZ. Alcohol seemed to work better than vinegar for me and it worked for only one button. WD40 got the other one loose. I used the silicone type which says it is water resistant and safe for plastic on the can. This all took me over 2 hours.
04-27-2020 22:22
04-27-2020 22:22
