08-19-2019
20:12
10:43
08-19-2019
20:12
10:43
My charge 3 belt was broken, and still within one year warranty. Therefore, I contacted support and get the replaced belt. However, when I tried to install new the belt, I found that one side of the fitbit is easy to take off from charge3, but the other side cannot take off, even I use my fingers, and also try a pen to push the button, but cannot take if off. The button just cannot press in. I even tried press the button and twisted the belt, still cannot take the belt off.
Two days ago, I contacted the fitbit support with an image to explain. An agent called Alvin quickly responded me ( I appreciate it) and asked for a video to prove myself. Then I sent a video to support. But I did not get any reply. This morning I reminded the support team again, but still no any response. I believe that fitbit support just intentionally ignore me.
Can anybody help me? Thanks in advance!
04-28-2020 11:50
04-28-2020 11:50
05-20-2020 11:12 - edited 05-27-2020 08:56
I had the same issue. Here are the steps I followed.
05-23-2020 12:02
05-23-2020 12:02
Same iisue here. Actually my band broke ao i was going to use my husbands band as he does not wear it anymore and cant get one side of his off! Of course its the same side that broke on mine😞
05-23-2020 12:45
05-23-2020 12:45
Put that side of the band that is stuck in simple green solution for a few hours to dissolve the dust, sweat n gunk that is making the band latch rigid. Once it's free, the band should come off easily.
05-25-2020 02:05
05-25-2020 02:05
That vinegar suggestion was perfect. I just used it to clean mine, then depressed the button a couple times while wet and it works like a dream. Now, to get my broken band off with that "dirt and sweat glue".... 😞
This also makes a point that I ought to clean these connectors once a month, especially working with saltwater.
05-26-2020 19:18
05-26-2020 19:18
06-05-2020 08:06 - edited 06-05-2020 08:26
Tks rrkpradeep for this info (re: post time-stamped 05-20-2020 11:12)! With this I figured out how to remove the plastic pieces and cleaned away all the gunk/dirt that got stuck within the parts. I applied a bit of silicon grease to the plastic contacts before putting all back into their places. Added some photos to help others who may want to do the same thing:
Note - Vinegar didn't do the trick for me, my watch the plastic piece was stucked solid and couldn't be depressed at all after soaking it in vinegar for 3 hrs. Tried alcohol and WD40 type lubricant as well. I gave up and had to use long-nose pliers to force it down (do it at your own risk though, you might damage the plastic piece - I did it as a last resort).
06-05-2020 08:10 - edited 06-05-2020 08:14
deleted - managed to edit my post above.
06-06-2020 20:20
06-06-2020 20:20
Awesome. Thanks for the photos. Makes it easier for others. I'm cleaning mine every 2 weeks as a preventative maintenance. Cheers!!
06-18-2020 08:53
06-18-2020 08:53
Just happened to me too. Aggravated to no end. If it cat be fixed I’m done with Fitbit and will switch brands. Hope there’s a response from Fitbit to this. If anyone has an update, it wil be greatly appreciated. Thanks.
06-18-2020 15:29
06-18-2020 15:29
06-18-2020 20:46
06-18-2020 20:46
06-18-2020 20:58
06-18-2020 20:58
OMG!! That worked instantly! Thank you SOOOO much!🥰😍😘😀
07-28-2020 15:24
07-28-2020 15:24
Have the same problem. Did get both sides off finally, but now I cannot get one side to stay on. The fitbit looks almost corroded. Cleaned it off but the one side of the new band will not stay on
07-28-2020 15:37
07-28-2020 15:37
07-28-2020 16:28
07-28-2020 16:28
07-28-2020 16:38
07-28-2020 16:38
08-18-2020 00:00
08-18-2020 00:00
Had similar issue. Its just that dirt and grime have jammed the latch. Soak the tracker in soap water or diluted vinegar for a while and then try and depress the latch. Should work. It worked for me. All the best.
08-18-2020 00:31
08-18-2020 00:31
09-05-2020 13:40
09-05-2020 13:40
I have just had to replace my Charge 3 ( blank screen issues) so had to remove the straps from the old unit so as to attach them to the new unit. One strap came off pretty easily but the other strap would not budge. Came straight on here and followed the helpful advice. In my case I dabbed the press button with a cotton bud dipped in white spirit and worked the but around the button and where the strap attaches. I then gave a short squirt of WD40 PTFE over the button area and wiped of residue. Gave it a couple of minutes then got a screwdriver and pressed the tip into the button and carefully pressed down. After a couple of goes and a quick pull of the strap and the strap was released. Success! When you look at the connection it is not difficult to see how they can get jammed with the gunk that builds up from just daily. I can recommend the above procedure as long as you are careful.
