06-13-2019
18:17
10:58
06-13-2019
18:17
10:58
Ok, as you can tell, my BRAND NEW charge 3 that I got hours ago’s band isn’t latching! The little piece that is supposed to go into the band and make it latch isn’t fully connecting to the band, even though the piece works fine without the band present. Any suggestions?
06-13-2019 22:57
06-13-2019 22:57
Hello and welcome to the forums @SnowTire
I've notified a moderator to stop by to help with some suggestions for you. Thanks for coming here.
Best Answer06-14-2019 06:04
06-14-2019 06:04
Welcome to the Fitbit Community @SnowTire. I'll be glad to assist you with your Charge 3 band inquiry.
Fitbit Charge 3 have 2 detachable wristbands (top and bottom) that you can replace with accessory bands sold separately. To remove and replace the bands on both sides:
I got in touch with our support team and they have informed me that they already assisted you.
@Odyssey13, thank you for the heads up.
Please let me know if you need further assistance.
10-26-2019 05:55
10-26-2019 05:55
I just bought my wife a new Fitbit charge 3, and a pack of various color replacement bands for it.
I decided to change the black band on my Fitbit charge 3 to another color. I found out the button on the buckle side will not push in to release the band. The other side released easily, and I replaced that side.
I have tried repeatedly, and cannot get the button on the side with the buckle to move at all, and cannot get the old band off. Do you have any suggestions?
10-28-2019 13:05
10-28-2019 13:05
Welcome to our community @Screwielouietwo. I'll be glad to assist you with your wife's Charge 3 band inquiry.
I went ahead and created a case on your behalf and a customer support representative will contact you soon. Please check your email.
Please let me know how it goes.
11-25-2019 18:12
11-25-2019 18:12
Hello I am having a problem with latching a new band to my fitbit and the old one will not latch back anymore. It is the side of the buckle.
03-07-2020 06:14
03-07-2020 06:14
The plastic piece on one side does not move down so the new band that I purchased won’t latch.
Best Answer07-02-2020 08:17
07-02-2020 08:17
I have the same problem, original band won't release on the buckle side... anyone found a solution?
Best Answer07-02-2020 11:26
07-02-2020 11:26
Well, it turns out that there was some sand/dirt in there.. i pried it off (the band was broken anyway) and then used baby oil to lube it.
Best Answer07-11-2020 14:33
07-11-2020 14:33
Me Too! I got mine July 7, and it came with 2 bands (and the small options, which connect great, but are useless for me), but the ‘special’ white band I paid extra for will not attach. It looks like it is ‘attached’, but won’t latch / pop the connector up on the device. Another issue Is trying to connect a band, the face is so sensitive it starts turning options on / off, switching displays, etc. but that’s a topic for another day. I’m hoping I can get a replacement band piece (the large side white band) 😕
Best Answer12-24-2021 16:29
12-24-2021 16:29
I have exactly the same. The new buckle won’t click and stay on and even the one I took off will not re-click and stay on so I am now unable to wear it - very frustrating!
12-24-2021 17:22
12-24-2021 17:22
12-24-2021 17:45
12-24-2021 17:45
Great thanks I will give that a try!
08:10
11:01
12-25-2021
08:10
11:01
Welcome to the Fitbit Community, @MuirG. Thank you for letting us know about your Charge 3 band.
As @MEMahaffey mentioned, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
