09-04-2019
07:45
10:43
09-04-2019
07:45
10:43
Not sure if anyone is experiencing the same, 3 days ago my Charge 3 started vibrating then it stopped working, I connected to the changer and it booted, then restarted the watch after that the back sensor is red and two thing are happening 1- My battery lasts less than 1 day, 2- No hearth rate at all.
Worse thing is that I sent a DM yesterday and no answer so far.
09-05-2019 06:43 - edited 09-05-2019 06:44
Hi @luiswongc, welcome to the Community Forums. I am sorry to hear that you are going through this situation. I appreciate your feedback and your efforts in troubleshooting your Charge 3 prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Let me know if there's anything else I may do to assist you with. 😉
09-05-2019 08:33
09-05-2019 08:33
Hey @MarreFitbit Support helped me with all the steps and I'll be receiving a replacement soon. Thanks a lot for the follow up 🙂
09-05-2019 09:40 - edited 09-05-2019 09:40
Great news @luiswongc! I'm very glad to hear that our Support Team is replacing your Charge 3.
Please don't forget that you can set up your new device on your currently Fitbit account without losing any previous data by following the steps below:
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
05-14-2020 07:19
05-14-2020 07:19
I'm also facing the same issue with my charge 3....can you please help me with it
05-14-2020 07:23
05-14-2020 07:23
Hi I'm Karthick and I'm from India. I have a fitbit fitbit charge 3 device and I faced the exactly the same problem... The device started to vibrate occassionally and the sensor flashed red light and I tried to charge and reboot the device...but it isn't working...can you please help me resolving the problem....I'm sorry that I'm troubling at this hard time...but thought it is appropriate to post the problem as soon as I encountered it...than you
05-14-2020 07:47
05-14-2020 07:47
Hi I'm Karthick and I'm from India. I have a fitbit charge 3 device and I faced exactly the same problem... The device started to vibrate occassionally and the sensor flashed red light and I tried to charge and reboot the device...but it isn't working. The battery is holding for just 1-2 days...can you please help me resolving the problem....I'm sorry that I'm troubling at this hard time...but thought it is appropriate to post the problem as soon as I encountered it...thank you
