Charge 3 battery dead in minutes
Battery says fully charged on Device and app, then within 15 minutes is fully drained and shuts off. Just purchased new in January. Need help.
5 REPLIES 5
@ChekieK Thanks for stopping by!
Let me help you with you with your Charge 3 battery draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
This did nothing. But now when I press and hold the side button nothing
happens, the device just vibrates for like 8 seconds and nothing even comes
on the screen anymore.
@ChekieK thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
I got mines the end of May and over the last few days mines has also been doing this. Fully charged and within very little time the battery is dead and it switches off.
@AnzoC Welcome to the Fitbit Community! It's great to have you here!
Thank you for reporting this issue with your Charge 3 battery. I noticed that you already have a ticket with our Support team so keep working with them to find a solution.
