05-08-2021
10:18
11:25
WilsonFitbit
05-08-2021
10:18
11:25
WilsonFitbit
Hi,
My Charge 3 battery has started dying, daily.
rjs52
05-08-2021 11:29
05-08-2021 11:29
Hello @rjs52. Welcome to the community forums!
Thank you for the information. I'd recommend performing a restart to your Charge 3. To perform a restart, please follow the steps here. Also, please make sure that your Charge 3 charges correctly, by plugging the charging cable that came with your Fitbit device into a USB port on your computer, a UL-certified USB wall charger, or another low-energy device.
On a side note, here there are some helpful tips to extend the battery life of your Charge 3.
Hope this helps.
Best Answer05-09-2021 14:33
05-09-2021 14:33
This happened to my Charge 2. When I contacted Support, they tried to troubleshoot the issue. Of course, that didn’t work and they noticed my device was still under warranty and I received new Fitbit in less than a week.
05-09-2021 21:25
05-09-2021 21:25
05-10-2021 04:29
05-10-2021 04:29
Hello @Ms.LisaC. Welcome to the community forums! Thanks for your great input!
@Ms.LisaC I'm glad to hear that a replacement Fitbit device has been sent to you! Hope you can continue tracking towards your fitness goals.
@rjs52 Thanks for your reply. If the tips above don't help, my best recommendation is that you please reach out to our Support Team for further assistance. They will be able to work on your case and provide you with more information. Click here to get connected.
On a side note, take into consideration that replacement devices are provided for products that are within the warranty period. Since your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty
See you around.
