11-28-2018
13:47
14:31
11-28-2018
13:47
14:31
My HR Charge 3 doesn't seem to hold its charge for longer than 3 days, is this a common fault. Was working well until 2 weeks ago holding charge for 7 days.
Moderator edit: Updated title for clarity
07-17-2019 16:52
07-17-2019 16:52
07-18-2019 10:27 - last edited on 02-07-2020 15:53 by LiliyaFitbit
Actually mine died whether so use it or not. Went on vacation for a week & didn’t take it. It was dead when I tried to wear it again. It is frustrating for sure!
07-18-2019 10:29 - last edited on 02-07-2020 15:52 by LiliyaFitbit
Thanks for sharing your experience. I’m hoping Fitbit will change my unit out before the warranty expires. It’s never held a charge from the beginning with minimal functions enabled.
07-18-2019 10:51
07-18-2019 10:51
08-11-2019 19:41
08-11-2019 19:41
I have had my charge 3 for less than a month and it is already draining extremely quickly
08-12-2019 04:37
08-12-2019 04:37
I’ve been experiencing the same problem that you have mentioned. Have you received any solution to this predicament?
08-12-2019 04:41
08-12-2019 04:41
I think that's the way the battery drain happens. If you look at my original description of the issue the battery when charged full at 100% would drop by 5-6% and be at 94% after 10-15 minutes. That was my issue. But I let it drop as it is and I am now consistently getting 5-6 days of battery life in one single charge to 100%. I although have disabled notifications and all day sync features though!
08-12-2019 05:00
08-12-2019 05:00
08-12-2019 09:04 - last edited on 02-07-2020 15:52 by LiliyaFitbit
Exactly! What is the point of having this device if you can’t use all of its features? I’ve got plenty of watches.
It was a gift otherwise I would have returned it. Going to use it as yet ‘another watch’ and keep charging it every third day. I appreciate getting phone messages on the Fitbit and knowing how much I’m walking. 😉
08-13-2019 08:54
08-13-2019 08:54
I've had my Charge 3 for about two months now. I originally was able to get a full week out of one charge, and I wore it non-stop. About three weeks ago I did an update, and ever since then it only lasts 24 hours. I've been through all the settings, and I don't see anything that I can change to increase battery life back to the way it was. This is unfortunate since it was a gift, and now I will most likely end up taking it back.
08-13-2019 14:36
08-13-2019 14:36
08-14-2019 16:09
08-14-2019 16:09
08-14-2019 16:36
08-14-2019 16:36
They replaced mine as well
08-14-2019 16:37
08-14-2019 16:37
I spoke with customer support. They wanted me to reset, change a few settings, and go through a complete battery cycle to see if it helped. Unfortunately it has not. I was at 100% last night. It has been 21 hours, and I'm already at 29‰. I sit in a cubical all day. There is no way it should be this drained. I'll be contacting customer service later tonight.
08-14-2019 18:34
08-14-2019 18:34
08-15-2019 07:24
08-15-2019 07:24
They are sending my replacement. It was fairly painless. Just had to fill out a form to prove when and where I originally bought it. Based of previous posts, I'll should be getting it sometime next week.
08-15-2019 10:28
08-15-2019 10:28
08-15-2019 12:39 - last edited on 02-07-2020 15:54 by LiliyaFitbit
I received my replacement Fitbit last week and everything as been fine. I’ve just noticed my battery dropping charge again fast.
I’ll keep you updated.
Moderator edit: format
08-15-2019 15:23 - last edited on 02-07-2020 15:52 by LiliyaFitbit
Thanks for letting me know. I do fear a replacement will be as bad or worse.
I’ve always killed watches with batteries. Maybe this is a similar problem?
08-27-2019 10:34
08-27-2019 10:34
Hello,
I've a charge 3 and today I've chatged it twice and still needs a further charge. Not even 6 months as yet. Very frustrating as I love the product, but 6 months and it's failing isn't good.
Chris
