11-28-2018
13:47
14:31
11-28-2018
13:47
14:31
My HR Charge 3 doesn't seem to hold its charge for longer than 3 days, is this a common fault. Was working well until 2 weeks ago holding charge for 7 days.
Moderator edit: Updated title for clarity
08-28-2019 14:00
08-28-2019 14:00
Best Answer09-07-2019 16:20
09-07-2019 16:20
My Charge 3 battery started draining rapidly today. Went from20% to 6% in 10 minutes. Charged it to 100% and it was at 9% in less than an hour.
09-07-2019 17:51
09-07-2019 17:51
Best Answer09-18-2019 05:36
09-18-2019 05:36
I'm on my third fitbit charge 3 in 9 months. They're fine for a short while and then the charge doesn't hold for a full day.
I've had to charge my device multiple times a day or have a dead device.
Fitbit had been great with my first device replacement but I had to pay £8 recorded delivery for my second, which took weeks to arrive after chasing it multiple times. This 2nd replacement is now failing to hold charge and I'm fed up with the device all together, my alta was half the price and worked well two years later, the charge 3 is not up to par
Best Answer09-18-2019 07:33
09-18-2019 07:33
Best Answer09-18-2019 14:36
09-18-2019 14:36
My charge 3 used to only last one day and a half. Fitbit wizards must have done something to the programing it is today on day 7 all features turned on and still have 35% battery
Best Answer09-18-2019 14:42
09-18-2019 14:42
Best Answer10-14-2019 06:28
10-14-2019 06:28
This is happening to mine as well! I wonder if they will replace it?
Best Answer10-17-2019 05:34
10-17-2019 05:34
Two days in a row my battery charge level went from hero to zero in 5 hours. I thought I maybe put it incorrectly on the charger yesterday but this morning it was definitely at 100%. It got to 5 by 12? Because it died on me yesterday I did a hard restart already.
Best Answer10-18-2019 16:54
10-18-2019 16:54
Best Answer10-18-2019 17:59
10-18-2019 17:59
Before you attempt calling you must first fully charge it and sync the device to the app. Then you need to be sure to syn it when it has drained. Like we all have time to sit around and monitor our fitbit's battery status. One it is low you must be sure to sync it again to the app. This will verify that it is in fact defective. Unless you do this they will not give you any information over the phone on how to return it or transfer your call. It is very frustrating. This seems to be an issue with the Charge 3 so it should not be an issue to have it serviced or replaced.
10-23-2019 08:59
10-23-2019 08:59
I'm in the same boat, battery only last 2 day, if I'm lucky
Best Answer10-23-2019 13:38
10-23-2019 13:38
Mine holds a charge for only 2 days. At first it was 5 days; seems to be declining. Now suddenly the time is 1 hour and 14 minutes off, even after syncing. I need to return mine for a replacement. Please approve.
10-24-2019 03:51
10-24-2019 03:51
Best Answer11-09-2019 06:54
11-09-2019 06:54
I've had my charge 3 for about 8 months working fine but today I charged it to 86%, put it on, wore it for about an hour, and it was at 13%. I charged it again to 51%, within 20 minutes it dropped down to 25%.
11-20-2019 07:06
11-20-2019 07:06
Having the same power problems with my Charge 3 and this is the replacement that FitBit sent me less than six months ago. Very frustrating!
Best Answer12-16-2019 14:52
12-16-2019 14:52
Same here. The Fitbit is a year old, it was working fine until 2-3 weeks ago and now battery drains down in couple of days tried restarting but after the bar starts it then converts to smiling face in a nano second
any perm fix? This is my 3rd Fitbit all 3 died after a year
Best Answer12-17-2019 05:12
12-17-2019 05:12
Best Answer01-02-2020 19:25
01-02-2020 19:25
Try cleaning the contacts on the watch and charger wire . Also don't use a charger higher than 1amp. Worked for me. I also reset the watch.
Best Answer01-02-2020 19:44
01-02-2020 19:44
