10-15-2018
23:28
15:06
10-15-2018
23:28
15:06
Has anyone had any issues with the charge 3 battery. My charge 3 is a week old and needed a charge Sunday night. I charged it over night and in the morning it was showing 100%, I wore it all day Monday however early hours of this morning (Tuesday) by watch was dead. I’ve had to hold the buttons for 8 seconds for it to come on however it ran out of battery? I synced my watch and phone before bed and there was over 80% battery. Has anyone’s else done this?
10-02-2019 21:23
10-02-2019 21:23
Contact Fitbit support they seem to be pretty helpful- that’s who I contact and if you read back on other reply’s their response seems to work. Good luck!
10-04-2019 19:37
10-04-2019 19:37
I have the same isue, after few months, suddenly it drains battery like more than 50 % per day, i have to charge after a day, i tried to rétart as supporter told but the problem still there
01-15-2020 03:17
01-15-2020 03:17
Hi.. my Fitbit charge 3 is facing battery issues. It is draining from 100% to 4% in hours.
I've already tried restarting as you've recommended. But there has been no improvement.
Please help
01-15-2020 07:04
01-15-2020 07:04
01-27-2020 03:34 - edited 01-27-2020 03:35
Thanks, Patty!
I got in touch with the support and they provided me with a replacement as the device is still in it's warranty.
04-11-2020 07:52 - last edited on 08-28-2020 20:15 by LiliyaFitbit
My hubby's Fitbit Charge 3 is dying everyday, and its not like it is getting used a lot....due to this quarantine, we are in the house a lot. We have talked to Fit bit support site, and they said to reset it. It flashes back and forth to another screen. It worked right for one day, now its back to the same craziness. They are not cheap to be getting these problems
Moderator edit: format
04-11-2020 17:08
04-11-2020 17:08
My Fitbit Charge 3 started draining more quickly within the last couple weeks. Now it drains immediately And I can’t even use it. It’s so frustrating because it’s not that old but probably not under warranty anymore. I’ve tried all the troubleshooting options. I don’t want to buy another one if this is going to happen again. Any hope that this could be fixed?
04-11-2020 17:12
04-11-2020 17:12
04-11-2020 17:19
04-11-2020 17:19
04-11-2020 20:58
04-11-2020 20:58
04-11-2020 23:59
04-11-2020 23:59
I did the same thing one year ago. Problem solved. I was sick and tired of all the bugs my Fitbit had, while many of them had not been resolved for more that 2 years. Apple Watch just works.
04-27-2020 22:44
04-27-2020 22:44
Mine just drained from 90% to 9% in less than an hour while I was on ca conference call.....have reset it so hopefully that will stop the problem
05-17-2020 07:16
05-17-2020 07:16
My wife’s has just gone down the same route discharges within 24 hours .
must be a bug in the charge three ??? Or some of them Anyway, as mine is ok for the moment
05-26-2020 10:42
05-26-2020 10:42
@Will999 @CJD21 It's nice to have you on board! Sorry for the delay in my reply.
Let me help you with your Charge 3 battery not holding a charge. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
05-26-2020 11:16
05-26-2020 11:16
05-26-2020 11:32
05-26-2020 11:32
@SunsetRunner thank you for the update.
Happy to hear that you were able to use your Charge 2 and hope it and the Versa helps you reach your fitness goals and keep a healthy lifestyle.
Happy stepping and stay safe.
06-07-2020 06:42 - edited 06-07-2020 06:44
Has there been a resolution to this issue .. Just yesterday, after a complete charge, my Charge 3 started discharging at a rate that the battery dies in <20 minutes. I have had this fitbit for 1 1/2 years. I had another fitbit before this and thought I'd upgrade....multiple problems but this one is the worst and renders this device unusable. I followed (or verify settings) in all steps listed in the post "Can I extend my Fitbit device's battery life?" as suggested by AlejandraFitbit in message #49 of this thread. PLEASE HELP!
06-07-2020 07:38
06-07-2020 07:38
06-21-2020 12:13
06-21-2020 12:13
@sanmar It's good that the community is growing!
Let me help you with your tracker's battery draining quickly and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me now how it goes.
08-28-2020 00:38
08-28-2020 00:38
I’ve tried this and it doesn’t help. My Fitbit Charge 3 has worked perfectly fine since I got it for Christmas in 2019 and starting earlier this week it’s died within 24 hours of charging it to 100%. Today it has died within hours of fully charging it and when I restart it, the battery will go down under 10% even if it was at 100%.
