10-24-2020
02:52
13:20
10-24-2020
02:52
13:20
Yesterday the battery of my Charge 3 started draining really quickly. Like, 100% at 9:02 and 89% at 9:10 (and I didn't even move). It has also stopped counting steps. So now it's useless :-(.
I got it in September as a warranty replacement because my previous Charge 3 had a problem.
Things I've tried so far:
- hooking it to the charger and holding the button until I saw the smiley face (4-5 times)
- restarting Charge 3 via settings on the device
- hard factory reset
I use a Samsung galaxy A51.
Also, since about 2 weeks ago my registered walks don't show me maps anymore even though GPS was connected. Before that they did. But according to customer service that has something to do with compatibility issues??? I think that's strange because before it worked fine.
Is my Charge 3 faulty or does anyone have the golden tip?
10-26-2020
10:51
07:08
10-26-2020
10:51
07:08
@IJsselmeisje Thanks for being part of our Community!
Sorry to hear that your Charge 3 isn't holding a charge nor getting GPS data and thank you for troubleshooting this issue. Regarding the battery I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Regarding the missing GPS data you can try the following:
Let me know how it goes.
10-28-2020 12:59
10-28-2020 12:59
Thanks! I got in touch with customer service and got the choice between a complimentary replacement or a 50% discount on a new Fitbit. Today my brand new Charge 4 was delivered! Awesome customer service!
