Charge 3 battery not charging
After downloading new firmware,  my battery drained very quickly, is empty & doesn't seem to want to charge. There is no battery face or anything else.
1 REPLY 1
@Galiz Thanks for joining us!
Let me help you with your Charge 3 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
