10-04-2019
13:45
03:57
AndreaFitbit
10-04-2019
13:45
03:57
AndreaFitbit
Hey there! This morning I noticed that my Fitbit was set to a completely wrong time (hours and minutes) and when I went to fix it later, the screen was totally black and the button wouldn’t do anything. I’m able to hold the button and get a continuous vibration, but can’t get the screen to come on at all. Tried plugging in and holding down the button to reset with no luck. Any ideas?
Moderator edit: format.
10-04-2019 13:46
10-04-2019 13:46
Forgot to add - also won’t connect to Bluetooth, that was my first sign that something wasn’t working right.
Best Answer10-04-2019 21:44
10-04-2019 21:44
Hi @BumbleBri I have flagged a moderator to come and help you
Helen | Western Australia
Best Answer10-05-2019 04:55
10-05-2019 04:55
Welcome to the Fitbit Community, @BumbleBri. I'll be glad to assist you with your Charge 3 behavior. Thank you for letting us know that the button won't do anything and that it won't connect to Bluetooth.
I went ahead and created a case on your behalf and a customer support representative will contact you soon. Please check your email.
@NellyG, thank you for the heads up.
Keep on visiting the forums.
11-14-2019 02:30
11-14-2019 02:30
My charge 3 vibrates regularly,why? It happened many times.what I should do?
Best Answer11-14-2019 05:13
11-14-2019 05:13
Hi there @Punitarohra, welcome to the Community Forums. Thanks for bringing this to my attention.
While reading your post I was wondering if this happens when you get any notification? Is your Charge 3 vibration repeatedly?
Please restart your Charge 3 by following the steps below:
Please let me know if this keeps happening after the restart, I'll be around and glad to further help.
07-02-2020 08:34
07-02-2020 08:34
Hi Moderator Andrea,
I'm having this same issue on my Fitbit Charge 3. The screen is black and all I can use the button for is to get a continuous vibration from holding the button down.
If I hold it down it vibrates for 5-15 seconds and even if I hold it past that point, it will resume vibrating in a continuous fashion for several intervals of seconds but will never reset. Please help!
This Fitbit is less than 2 years old and I use it daily. It really bums me out this happened as I expected to have this product last longer. If the limited warranty was only for 1 year it makes me wonder if that's how long FitBit expects the product to function correctly for its customers.
Thanks for your help!
08-10-2020 16:21
08-10-2020 16:21
I have the same issue i really need help can u guys help me what to do.
01-15-2021 09:40
01-15-2021 09:40
I Have the same issue,
Device only continues vibrate when its charge and press on the button .
Can't connect to BT. i think its dead, because i didn't using in for 3 month. but still vibrate when charging.
Best Answer04-25-2021 14:08
04-25-2021 14:08
My fitbit suddenly went blank today. Then when I tried charging it and held the button, it continuously vibrates and does not restart. It sounds like the same issues that others have been having in this thread. Does anyone have any advice?
I've been using my fitbit charge 3 for over 1 year already.
Thanks!
04-25-2021 14:15
04-25-2021 14:15
I've tried plugging it in and holding the button for 1 minute and it just vibrates for that entire minute and doesn't restart. Is my Fitbit Charge 3 dead?
07-18-2021
16:52
06:11
WilsonFitbit
07-18-2021
16:52
06:11
WilsonFitbit
I am having this exact issue with my Charge 3. Did you ever find a solution?
Best Answer07-19-2021 06:10
07-19-2021 06:10
Hello everyone. @rharvey Welcome to the community forums!
Thank you for the detailed information and for any steps you've followed prior to posting. At this time, I was able to see that you tried to contact our Support Team through chat, but your chat got disconnected.
In this case, if you still require further assistance, I recommend trying to contact them one more time through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat.
See you around.
Best Answer07-19-2021 08:12
07-19-2021 08:12
Best Answer07-19-2021 08:17
07-19-2021 08:17
Thanks for getting back to us and I´m sorry to hear that your Charge 3 is just dead @jenniferfawn.
I hope your new device arrives soon so you can get back on track.
Best Answer07-19-2021 13:10
07-19-2021 13:10
I have experienced a similar issue this evening. My Charge 3 started vibrating continuously. The screen was blank and there was no response to my pressing the button. I attached it to the charging cradle, the vibrating stopped and I attempted a soft reset. There was a brief repeat of the vibration but no other response. I attempted the soft reset several times but without success. I then noticed that the device had become very hot and I removed it from the cradle. It has cooled now that it is disconnected.
I would value your advice.
Best Answer07-19-2021 13:30
07-19-2021 13:30
Welcome to the Fitbit Community, @Bursar. Thanks for letting us know that your Charge 3 started vibrating continuously and the steps you have followed in order to fix it.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer07-19-2021 23:58
07-19-2021 23:58
Best Answer07-20-2021 03:52
07-20-2021 03:52
Best Answer07-20-2021 04:38
07-20-2021 04:38
Thanks for getting back to us @Bursar. I'm glad to hear that you received a satisfactory solution with our online chat facility.
See you around.
