01-25-2021
03:12
03:18
AlvaroFitbit
01-25-2021
03:12
03:18
AlvaroFitbit
This morning when I attached charging cable (wall plug), it did not vibrate, did not light up the battery showing charging. I removed it from charging cable and it won't respond to button with anything other than vibrating. It vibrates as long as I hold the button down. I brought charging cable to my computer and plugged it in there. Same thing. I can't restart, if I can't view a screen. I can't restart while attached to computer via cable, because I can't get anything to come up on the screen. I've held the button down for 10-12 seconds three times now. I think I'm just using up the battery charge.
It worked fine before I plugged it in to charge. Although, I've noticed lately it has been slow to attach to charging cable, some days I'd have to try 2-3 times to get it to start charging.
Is there anything else to try, or is it just dead?
01-25-2021 03:19
01-25-2021 03:19
@Mwisemiu It's great to see you in the Community!
Let me help you with this and thank you for troubleshooting this issue. It could be that the tracker is having difficulties charging so you can follow these instructions to help your device charge. After this retry the restart as you previously did.
Let me know how it goes.
01-25-2021 03:43
01-25-2021 03:43
01-25-2021 06:54
01-25-2021 06:54
Can you still pair it with your phone? What does the level of charge show when you connect your fitbit to a phone, and can you see it go up?
I'd check the charge level of your fitbit on your phone, as sadly, your screen might have died.
01-25-2021 07:14
01-25-2021 07:14
01-25-2021 10:33
01-25-2021 10:33
@Mwisemiu thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
@ducker thank you for your help here.
01-25-2021 12:35
01-25-2021 12:35
01-25-2021 23:28
01-25-2021 23:28
I picked up my Fitbit this morning. It had a heartbeat, literally. LOL. Kind of like it was trying to vibrate but the best it could get out was a weak blip about one per second. I couldn't get it to light up. But I thought I'd try to charge it. See what happens. So I've plugged it in and it gave me a smiley face. After a minute, it has 1% charge. So I guess the screen isn't toast. But I don't think I can trust it. Maybe it will limp along a while longer though. I'll keep my old one charged. Just in case.
Thanks for all of your help. I will let you know how it behaves after charging, and if I have any more problems with it.
Marie
