10-15-2018
20:59
15:03
10-15-2018
20:59
15:03
It seems my Charge 3 broke down last evening after some 6 days of usage. At around 22:30, when I was reading in bed, it vibrated shortly as if there was a notification. The screen stayed black though; there is no display. From that moment on the Charge 3 has been unresponsive. Screen as well as button doesn't react to touch or presses any more. The heart rate sensor is emitting light constantly (green all the time, instead of slow flicker).
Connecting it to the charger doesn't change anything: no charge indication and symptoms stay the same. So no way to reboot either.
What to do next?
I'll contact my supplier in the evening, have a busy day at work today
HR sensor on all the time...
button and screen don't react to touch or presses
01-31-2019 12:48
01-31-2019 12:48
Just wanted to pitch in, I know this is an older thread, but I found a different solution to the same problem.
I had the same issue, my screen went blank, and everything else was working. I fixed it by changing the clock face. As soon as I selected a new clock face, the screen started to work again.
Hoping this might help someone else experiencing the same issue.
01-31-2019 16:08
01-31-2019 16:08
Best Answer01-31-2019 16:09
01-31-2019 16:09
02-01-2019 10:25
02-01-2019 10:25
So glad I read through most of the threads on this issue. My Charge 3 did the same thing this morning, blank screen, but every thing else worked. I didn't do any reset. Glad I didn't, because following your lead, all I had to do was change my clock face and it came back on!
Thank you for sharing!
02-01-2019 11:13
02-01-2019 11:13
I had the same problem my screen suddenly went black today. I read a comment on here to change the clock face, which I tried and it worked! Let’s see how long it lasts now.
02-01-2019 11:30
02-01-2019 11:30
Best Answer02-01-2019 21:51
02-01-2019 21:51
This is not a solve...? Wtf
Best Answer02-02-2019 09:45
02-02-2019 09:45
Well it solved the problem for me and at least one other commenter on here, but if your Fitbit is not responding at all and you’re not able to use the app on your phone, then it will not work for you. I was just relieved that I didn’t have to go through support to have it replaced.
Best Answer02-04-2019 08:05
02-04-2019 08:05
my bad man, the thread on my phone display didn't have a "go to solution" or green highlighted section. just lazy af on a friday night apparently
02-06-2019 14:06
02-06-2019 14:06
YES! This worked for me. Thanks.
02-07-2019 13:07
02-07-2019 13:07
Hi, I had the same problem and followed your suggestion and it worked for ma as well.
Best Answer02-07-2019 20:31
02-07-2019 20:31
Thank you for this! My fitbit was working fine then I got blown up with text notifications and bam...display refused to work.changed the clock face on the app and bam...back to working.
Best Answer02-07-2019 21:24
02-07-2019 21:24
That just worked for me too! Thanks!!
Best Answer02-08-2019 04:06
02-08-2019 04:06
My charge 3 screen is currently blank out of the blue. I have tried rebooting but to no avail. Just bought it for few months. What should i do?
Best Answer02-08-2019 10:39
02-08-2019 10:39
I put detailed instructions elsewhere on this site, but what worked for me is going into the fitbit settings on my phone and changing the watch face display. Try that and see if it works.
Best Answer02-08-2019 11:07
02-08-2019 11:07
It’s only blank when I check the results on sleep and also I can’t find reboot anymore (I’m not talking restart )
Best Answer02-11-2019 12:51
02-11-2019 12:51
The display is totally black. No clock...no anything. Vibrates when message comes in...but screen is black.... Dead to the world.
Disappointed to say the least
I got it as a gift...and I won't recommend it to anybody....period
Junk !!!
Best Answer02-11-2019 12:52
02-11-2019 12:52
Well I doubt they will be calling me .45 day warrentee.... Crap
Best Answer02-11-2019 13:12
02-11-2019 13:12
Well I did just that . I connected the charger ...but it wasn't dead . I then pressed the side button for eight seconds...it came back with a smile .
But it just quit for no reason at all ? Wasnt low on battery...didn't drop it...didn't swim with it. Haven't really put it to test...even my doctor thinks their a joke. Waste of money...unreliable
Best Answer02-11-2019 13:53
02-11-2019 13:53
Try loading your clock again. It worked for me.
