10-15-2018 20:59 - last edited on 11-17-2020 15:03 by MatthewFitbit
It seems my Charge 3 broke down last evening after some 6 days of usage. At around 22:30, when I was reading in bed, it vibrated shortly as if there was a notification. The screen stayed black though; there is no display. From that moment on the Charge 3 has been unresponsive. Screen as well as button doesn't react to touch or presses any more. The heart rate sensor is emitting light constantly (green all the time, instead of slow flicker).
Connecting it to the charger doesn't change anything: no charge indication and symptoms stay the same. So no way to reboot either.
What to do next?
I'll contact my supplier in the evening, have a busy day at work today
02-27-2019 11:30
02-27-2019 11:30
This happened to me this morning. The hard restart while charging did not work. The edit to clock faces does not work. It tells me my fitbit is not connected (even though it is syncing, showing sleep data etc.). Lately it has been showing only simple sleep details and has been struggling to sync, so this is the last thing that could go wrong I guess. Any other fixes besides calling into help desk? If not, will have to request a replacement. TIA.
02-27-2019 17:25
02-27-2019 17:25
03-01-2019 10:12
03-01-2019 10:12
That is what happened with my first watch. At the time I had not known about the clock face update and I have no idea if it would work since I have never tried it again on that watch. I'll try and sync it tonight and get back to you.
They replaced mine after troubleshooting with the tech for several hours.
03-02-2019 16:48
03-02-2019 16:48
@JuanJoFitbit Just to be clear, the Charge 3 software is NOT working properly, and this is just a stop gap measure. This bandaid does not work for users that can't sync to their phone for whatever reason and even if it does work it only temporarily resolves the issue. I have had my Charge 3 for less than 2 months and I have had to change the clock face twice.
03-02-2019 19:57
03-02-2019 19:57
@samsq wrote:
@Remi22 wrote:I had the same problems ,(black screen) on my charge 3. I could still see progress on my phone but I need a watch. I went to change clock screen and picked a new one and for now it works. Not sure why but glad I experimented.
My screen also went blank. Nothing I tried seemed to work. However, reading the commments here, I changed the clock face. Initially, I just had a white line across the face, but now it appears to be ok. Thank you for the heads-up about changing the clock face. Fingers crossed it will be fine now.
UPDATE
TWO WEEKS ON FROM THE FIRST BLANK SCREEN / CLOCK FACE REBOOT AND IT HAS HAPPENED AGAIN. IF IT HAPPENS A THIRD TIME I WILL KNOW THAT THIS FITBIT IS NOT "FIT FOR PURPOSE" AND WILL BE REQUESTING A REPLACEMENT. (TWO RESETS IN A LITTLE OVER TWO MONTHS OF PURCHASE)!
FITBIT THIS IS NOT GOOD ENOUGH!
I HAVE ONLY BEEN WEARING THIS FITBIT SINCE THE NEW YEAR!
03-04-2019 18:10
03-04-2019 18:10
This worked for me! Thanks for the suggestion.
03-04-2019 19:00
03-04-2019 19:00
03-05-2019 13:51
03-05-2019 13:51
I managed to fix my by loading the app and changing the clock face. Once done little progress bar on screen and all good again.
Cheers,
Paul
03-08-2019 06:56
03-08-2019 06:56
Not a solution for me. My watch face was blank with the watch still at a half-charge indication. The watch still worked-heart rate data still recording, and the watch still synced-just no screen. The later thread suggestion to change screens did work for me- changing to a new screen(screen then worked) and then changing back to the preferred classic screen has fixed the problem so far. Interesting glitch-changing screens must act somehow as a reboot of the watch display. . .
03-08-2019 18:08
03-08-2019 18:08
I have the same thing happening. What should I do?
03-10-2019 08:50
03-10-2019 08:50
I contacted online chat and they told me to do the 8 second reset then go immediately to the app and choose a different clock. I did this and my screen is working again!!
03-10-2019 15:39
03-10-2019 15:39
Thanks this totally worked for me
03-11-2019 07:37
03-11-2019 07:37
My fitbit was 10 days out of package when it started going blank. I did the clock face change, but it only helped until next time battery drained. Mulitple resets and calls to customer service, and, after a drawn out back and forth with customer service about my now 2 month old fitbit being under warranty, I am awaiting replacement.
03-12-2019 14:35
03-12-2019 14:35
I’m having the same issue, it’s been working fine for about a month, I only take it off to charge it, other than showering it hasn’t been immersed. I tried to swipe on my screen at gym this morning and it wouldn’t budge, I can see main clock but won’t scroll up or down left or right. Charged it fully, turned it off and changed clock, still non responsive??
03-12-2019 14:53
03-12-2019 14:53
03-12-2019 23:10
03-12-2019 23:10
This just fixed my black screen issue of a Charge 3!!! It’s the weirdest thing and I hope it lasts but after reading all unsuccessful try outs this caught my eye as the one that work !!!! Sure enough it did and I was even able to return to the previous clock face -still working! Thank you 😊
03-13-2019 15:55
03-13-2019 15:55
Thank you, it worked for me also!
03-16-2019 09:48
03-16-2019 09:48
Hi. You can go to youtube and a guy will tell you what to do.. use your phone device on the application. then hit clock faces and wait.. it works
03-16-2019 12:20
03-16-2019 12:20
My Fitbit will not respond to anything. The screen stays black. I don’t know how to reset it. Pushing the side button/slot or tapping it does nothing.
03-16-2019 12:25
03-16-2019 12:25
