05-28-2021
18:00
04:26
WilsonFitbit
05-28-2021
18:00
04:26
WilsonFitbit
Fitbit has turned on my GPS on my phone and this is running down my battery. My fitbit screen is blank so cannot see what is going on with.
05-29-2021 04:30
05-29-2021 04:30
Hello @Clodcruncher. Welcome to the community forums.
Thank you for the detailed information. If the GPS on your Phone is activated, take into consideration that you can turn it off to preserve battery. For more information, I recommend visiting the following link: How do I use GPS on my Fitbit device? Also, there is a link that contains instructions if in case your Charge 3 experiences any inconvenience with the battery life. For details, please check: Can I extend my Fitbit device's battery life?
Regarding the screen inconvenience, I recommend visiting the following thread for tips and suggestions.
Hope this helps.
