06-07-2019
09:13
10:55
06-07-2019
09:13
10:55
I have a charge 3 and I can’t get it to do anything but vibrate when I push the button on the side of it. I plugged it up last night and it showed a smiley face.
Got it off the charger this morning and it continues to have a black screen but still vibrates when I push the side button. It used to flash a light on the underside when I would take it off. Now it doesn’t even do that ?
06-08-2019 08:26 - edited 12-28-2019 09:05
Welcome to the Community Forums @Darinscharge3! Thanks for trying to restart your Charge 3 to solve the issue with the screen.
If the restart doesn't work, since your Charge 3 is vibrating (and maybe syncing as well), please try changing the clock face to a different one. This process is done through the Fitbit app, so don't worry if you don't see anything on the display by now.
If your tracker is not charging, see: Why isn't my Fitbit device's battery charging?
Give this a go and let me know the outcome.
06-09-2019
16:26
11:04
06-09-2019
16:26
11:04
Hi. I tried to change clock face.
But I can’t get it to sync ! So at this point it won’t sync so I can’t
trouble shoot anything or try to make any adjustments to fix it.
It still has a black screen and does nothing but vibrate when I press the
button on the side.
Thanks
Sent from my iPhone
Moderator edit: removed personal information
06-10-2019 11:08
06-10-2019 11:08
Hi there @Darinscharge3! Thanks for coming back and trying the recommendation I suggested.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if there's anything else I may do to assist you in the meantime.
Best Answer06-10-2019 11:38
06-10-2019 11:38
Hello, I have the same issue with my Charge3. Sometimes it is vibrating, but not starting the screen and without working sensors at the bottom. How can I contact some Fitbit support?
Thanks in advance!
06-10-2019
18:13
11:48
06-10-2019
18:13
11:48
Right now I’m waiting on Fitbit to give me some direction. I think they are
creating a case for me.
Best Answer06-11-2019 12:00
06-11-2019 12:00
Welcome on board @Samir_Kocholu! Thanks for reporting to us about your Charge 3's behavior.
Please try changing the clock face to a different one. As mentioned, this process is done through the Fitbit app, so don't worry if you don't see anything on the display by now.
Hello @Darinscharge3!
It seems that you already received a response from our Support Team.
I'll be around, keep me posted.
Best Answer06-12-2019 12:40
06-12-2019 12:40
Best Answer06-13-2019 11:46
06-13-2019 11:46
Hi @Samir_Kocholu, thanks so much for following my suggestions.
Since your device is still not working properly, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
I'll be around if there's anything else I may do to assist you with.
Best Answer08-09-2019 14:16
08-09-2019 14:16
My charge 3 is not displaying anything, only vibrates when I push side button. It will not reboot or sync. Changing clock face did not work(syncing issues). Also will not vibrate when put on charger.
08-09-2019 17:01
08-09-2019 17:01
Having the same issue as the others. Black screen, no sensor lights, occasionally vibrates, and unable to sync.
08-12-2019 14:31
08-12-2019 14:31
Welcome to the Community Forums @Merckx and @Ty_8311! I'm sorry for the late response. Thanks so much for following the tips and recommendations provided above.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Best Answer12-06-2019 13:34
12-06-2019 13:34
I am now also experiencing the same issue as the others. Initially started out with the Fitbit unable to sync, then when I followed the troubleshooting tips no luck there. Then tried to reinstall the device and pair it up again but found that while it saw the Fitbit, it would not pair (tried this several times over the past month) and now the Fitbit screen has gone blank, still vibrates and has no green light on the display. I cannot change clock face on app as the Fitbit would not pair to it so I apparently have bought an expensive vibrator not a tracker.
12-06-2019 14:22
12-06-2019 14:22
12-09-2019 06:28 - last edited on 02-14-2020 16:39 by LiliyaFitbit
Mine is collecting dust some where at the house. It seems like Fitbit is
more interested in selling them than replacing them.
Don’t have the time to jump thru all the hoops! Seems like it would be
pretty simple to send a return turn package to you. And then they could
determine whether it is repairable !
Or if they should replace it with comparable model. Good luck !
Sent from my iPhone
01-13-2020 20:26
01-13-2020 20:26
Mine is doing this exact thing. I have tried to change clock face, but have a sync issue. Need new software but have sync issue. Have restarted both devices several times. Watch isnt even showing up on pairable devices on my phone. Vibrates every time I touch the side. Gives me momentary smiley when first plugged in. Please help!
01-14-2020 05:42 - last edited on 02-14-2020 16:41 by LiliyaFitbit
I don’t know what the issue is with the charge 3 model ?
I have spoke to several people that have had the exact same problem or
something very similar to ours. I had my charge 3 less than a year before
it started acting up ! It would be nice if Fitbit would back up there
product and replace or repair them ! I have had no luck getting Fitbit to
offer any type of help ! Good luck !!!
Sent from my iPhone
01-14-2020 06:56
01-14-2020 06:56
I have had my fitbit since May 2019 and I love it. Yesterday it stopped lighting up. It is still syncing with my app, but no display. I tried both types of reset and changed the screen, but still no smiley face or display.
Best Answer01-31-2020 02:54
01-31-2020 02:54
have you received a fix? my does not work, sync or restart, it only vibrates when i am pushing the button
01-31-2020 07:37
01-31-2020 07:37
Purchased two charger 3 at Xmas. Have only achieved setting one up. This now doing exactly this. I'm just about to go to the trading standards as the item is not fit for purpose!
