09-30-2019
06:19
10:43
09-30-2019
06:19
10:43
I tried troubleshooting and couldn't find a solution. My Charge3 is going crazy. It has a black screen and vibrates almost nonstop. The button isn't responsive and plugging it in doesn't change its behavior. It did show me the battery/smiley face icon when I plugged it into the computer instead of the wall outlet but it didn't do anything different beyond that. Just wondering if there is something else I could try. It's less than a year old. I wear it everyday and it's helped me so much that now I'm lost without it! Any help would be greatly appreciated. Thanks!
10-01-2019 07:13
10-01-2019 07:13
Hello there @TaraGaston, welcome to the Community Forums. Thanks for already restarting your Charge 3 prior to contacting us. I will be more than glad to help and get you back on track. 😉
Since the restart didn't work, I'd recommend restarting your Charge 3 using the 15-second method:
If the long restart does not work either, please check on the Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
Best Answer10-01-2019 07:13
10-01-2019 07:13
Best Answer10-01-2019 09:27
10-01-2019 09:27
10-01-2019 13:57
10-01-2019 13:57
Hi there @TaraGaston, thanks for getting back and following the tips and recommendations I've provided.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you in the meantime.
Best Answer10-11-2019 20:17
10-11-2019 20:17
My issue has been resolved, thank you so much!
10-14-2019 08:25
10-14-2019 08:25
You're very welcome @TaraGaston! 😉 I'm glad to hear that your issue has been solved.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer01-27-2020 19:23
01-27-2020 19:23
Mine does the same. The long restart doesn’t work either. If I push the power button it vibrates but the screen is blank. I can’t change the clock face cause the app doesn’t find my Fitbit. I only had it since the end of September
01-27-2020 19:43
01-27-2020 19:43
I've tried resetting my fitbit charge 3 by holdi g down the button for 15 sec. It vibrates, but I do not see a happy face when i disconnect. Also, the charge symbol does not appear when I connect the watch to the charging cable. This problem is intermittent., but today, I have experienced a blank screen most of the time. I checked the fitbit app and it is not syncing with the watch.
01-28-2020 08:44
01-28-2020 08:44
Hi there @Bam693 and @Nicbc, welcome here. Thanks for the details provided about your Charge 3 trackers.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this.🙂
Let me know if there's anything else I may do to help you.
Best Answer02-01-2020 19:07
02-01-2020 19:07
how did they resolve it? I’m having this same issue right now.
black screen
not registering on my app
no heart rate green light on the back
02-01-2020 20:03
02-01-2020 20:03
Finally contacted someone in the live chat. Basically, my fitbit charge 3 is dead. Since I had it for 15 months, it was out of warranty. So, I was offered a discount on a new tracker.
02-01-2020 21:41
02-01-2020 21:41
Best Answer02-03-2020 06:28
02-03-2020 06:28
Best Answer02-03-2020 07:10
02-03-2020 07:10
Best Answer02-03-2020 09:26
02-03-2020 09:26
Hi there @Jezzydp, welcome on board. Thanks for the details provided. I've seen you contacted our Support Team after posting here and that they have helped you with this. 😉
Thanks for sharing the outcome of this situation with us @Nicbc and @Bam693.
I'll be around if you have any questions present.
Best Answer08-12-2020 04:24
08-12-2020 04:24
I have the same problem. I have tried to change the clock face but app says fitbit not connected. Also tried the long restart but nothing works. Screen still blank and vibrate erratically.
Best Answer08-13-2020 10:16
08-13-2020 10:16
Hi there @Tamslive, thanks for stopping by and for following the steps and suggestion I shared above to fix your Charge 3's blank screen.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best Answer08-13-2020 11:39
08-13-2020 11:39
11-16-2020 10:44
11-16-2020 10:44
Mine is currently doing the same thing. What ended up working for you?
11-16-2020 16:43
11-16-2020 16:43
