01-24-2020
14:17
17:42
01-24-2020
14:17
17:42
Hello,
My new Fitbit completely ran out of battery, however when I put it on charge the screen stays blank and it constantly vibrates pulses. (Stops when I remove charger) I have tried to restart with the 8 second and the 15 second method, neither worked. Although holding down the button gives a slightly longer vibration before returning to pulsing. My device won’t sink to the app either as the watch is off. I have also checked the charger and watch connections are clean.
can anybody help?
thanks, Katie
01-25-2020 08:41
01-25-2020 08:41
Hi there @Katie.q9, welcome to the Community Forums. Thanks for the details provided about your Charge 3's behavior and for taking the time to troubleshoot it prior to contacting us.
My first recommendation would be to let your tracker charging for at least 1 hour. Then, restart the Charge 3 once again by following the steps in the help article: How do I restart my Fitbit device?
If the restart doesn't work and the display is still not turning on after performing the steps above, please take a look at the help article: Why isn't my Fitbit device's battery charging?
We recommend to charge your Fitbit via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. For best results, don’t leave your device plugged in on the charger longer than overnight.
Tips to better charge your Fitbit:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Keep the charging contacts on the back your device and the pins on the charging cable clean and free of debris. For more information, see: How do I clean my Fitbit device?
Give this a go and let me know the outcome.
