12-03-2018
19:33
07:29
AlejandraFitbit
12-03-2018
19:33
07:29
AlejandraFitbit
My Fitbit is fully charged yet it will not show anything on the display screen, . When pushing the sides it vibrates but will not display the time, it’s is only 1 month old and was working perfectly an hour ago, any one any suggestions, thanks!
08-09-2019 11:12
08-09-2019 11:12
I’ve had my Fitbit Charge 3 since April 2019 it’s been working great until today the screen went blank? When I push side button it vibrates but does not show anything on screen.
please help!
08-09-2019 11:17 - last edited on 02-16-2020 17:19 by LiliyaFitbit
Connect the charger and keep the button pressed for some time until the
light comes on. It should work.
Best regards:
08-09-2019
12:49
06:16
JuanJoFitbit
08-09-2019
12:49
06:16
JuanJoFitbit
Everything good thank you 🙏
Thank you that worked
Sent from my iPhone
Moderator edit: merged reply
08-10-2019 20:43
08-10-2019 20:43
Happy to hear that it worked.
08-28-2019 11:32
08-28-2019 11:32
I am having the same blank screen issue, and have the latest firmware. What can be done???
08-28-2019 12:29
08-28-2019 12:29
Contact Fitbit support through the App! I suggest doing the live chat vs email... when I did the live chat they had me try a couple things and in under 10 minutes I'd had confirmation that my new one had shipped! The customer service has been excellent!
08-28-2019 12:31
08-28-2019 12:31
Doesn't work. None of the advice including the "accepted solution" actually works. How many more times do I have to bloody well do the reset and try to pair the thing?
08-28-2019 12:40
08-28-2019 12:40
Same thing happened to me. Fitbit Live support had me try it and immediately shipped a new one.
09-01-2019 07:47
09-01-2019 07:47
I am having the same issue as well. I just got my charge 3 yesterday although i bought it on March 2019. Happily charge my fitbit, download fitbit app on my phone, then update firmware for the watch and all i get is blank screen but vibrate when pressed. Tried to press for 8 seconds or 15 seconds for few times but can't solve anything, changed clock face when the watch is still connected to phone also can't solved, tried to set up again also can't since the watch is not showing numbers on it. What should i do then?
09-01-2019 08:02
09-01-2019 08:02
09-01-2019 08:11 - last edited on 02-16-2020 17:20 by LiliyaFitbit
Please try pressing the button with the charger properly connected. This
may activate your Fitbit charge 3. Good luck.
Lalith.
Best regards:
09-01-2019 08:25
09-01-2019 08:25
09-01-2019 08:40 - last edited on 02-16-2020 17:19 by LiliyaFitbit
Whilst being charged? With the charging unit properly connected?
Best regards:
09-01-2019 09:41
09-01-2019 09:41
09-01-2019
10:16
04:18
JuanJoFitbit
09-01-2019
10:16
04:18
JuanJoFitbit
Yes and yes.
Thank you, that had not been offered to me yet... purchased in January, issues started about 3 weeks ago.
Sent from my iPhone
09-01-2019 10:53
09-01-2019 10:53
09-01-2019 11:08
09-01-2019 11:08
09-01-2019 16:43
09-01-2019 16:43
Tried few times to connect on the charger, nothing comes out even the charger is connected.
09-02-2019 06:12
09-02-2019 06:12
I have same problem last week, after read other comments. I updated clock screen in Fitbit App (see bar loading 5 min) after finishing update the screen come back.
Thanks to gr82brees resolved comment !!!
09-02-2019 07:05
09-02-2019 07:05
