11-29-2021
12:38
16:50
EdsonFitbit
11-29-2021
12:38
16:50
EdsonFitbit
I can't read the time or steps on my Charge 3 because the brightness is so low. I found where to bring the brightness up one time and did it. So why is it so low again. Also I forgot how to get there. Thanks! Callie!
12-01-2021 08:40
12-01-2021 08:40
swipe left all the way to settings, then brightness, change it to normal for a brighter screen
12-01-2021 19:15
12-01-2021 19:15
12-05-2021 16:49
12-05-2021 16:49
Welcome to the Fitbit Community, @callie2021.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for trying to get them resolved before contacting us.
I noticed that you've been in touch with Customer Support. I'm pretty sure they've done their best to provide a high level of support. Thank you for your patience while dealing with this situation.
Thanks for your support, @temporaldoom.
Have a nice day.
Best Answer12-06-2021 03:41
12-06-2021 03:41
For me doesnt work. I tried to re configured and doesnt work
i eliminated from the app and tried to uploaded again but i can't because i cant even seen the new number on the screen
connected to computer, press on the left bottom, nothing works..and there any telef to support here in spain and monitoring from the Spanish support team
12-06-2021
11:04
12:23
EdsonFitbit
12-06-2021
11:04
12:23
EdsonFitbit
Mine appears to be quitting on me, too.
...And it's not that old.
Doesn't solve the problem, it looks like the display might be dying. It's only 15 months old.
Moderator edit: format
12-06-2021 12:17
12-06-2021 12:17
Im having exactly the same issue. Despite my settings being on Normal the display is gradually getting dimmer. Sometimes I can’t read the screen at all.
12-06-2021 12:22 - edited 12-06-2021 12:31
Thank you for visiting the Fitbit Community, @soniafa @BuffaloBob @Natlew.
Thanks for the time you spent trying to resolve the issues with your Fitbit Charge 3 devices.
@soniafa @BuffaloBob Our records indicate that you both have been in touch with Customer Support. They should let you know how to proceed as soon as possible.
@Natlew If you haven't done so, please restart your Tracker by following these steps.
In addition, please make sure Sleep Mode and Do Not Disturb (DND) are turned off. For instructions on how to navigate your Tracker, please visit this article.
Have a nice day.
Best Answer12-06-2021 16:09
12-06-2021 16:09
12-07-2021 16:15
12-07-2021 16:15
Thanks for your response, @callie2021.
Our team is constantly working to improve our products and services. Your feedback is highly appreciated.
Have a nice day.
Best Answer12-11-2021 13:26
12-11-2021 13:26
I have a Charge 3 as well with a screen that's faded to black and useless to me. This is my third Fitbit. I like them--when they work, but I don't like their less than stellar lifespan. I would love to simply upgrade to a new model, but I'm very reluctant to do so at this point. Problem is, I'm not sure what a comparable substitute would be and product reviews on some I've looked into range from terrible to wonderful.
What did you wind up buying, Callie?
12-11-2021 18:08
12-11-2021 18:08
My display is vey dim on the edges and totally unreadable in the center. I tried troubleshooting with tech support support this morning and the result was telling me that after less than a year my Charge 3 is out of warranty. Big help.
Best Answer12-12-2021 05:53
12-12-2021 05:53
Best Answer12-12-2021 07:47
12-12-2021 07:47
Best Answer12-12-2021 20:32
12-12-2021 20:32
Best Answer12-13-2021 06:29
12-13-2021 06:29
Amazon sells replacement battery for the charge 3, there is a you r
Amazon sells the replacement battery for the charge 3 for $15. There is a you tube video showing how to replace it.
Best Answer12-13-2021 07:23
12-13-2021 07:23
Best Answer12-13-2021 08:30
12-13-2021 08:30
