01-13-2021
07:15
08:20
AlvaroFitbit
01-13-2021
07:15
08:20
AlvaroFitbit
I managed to setup my Charge 3 but suddenly it's stop sync. Then, I delete the sync, however, when I want to setup again, the Bluetooth unable to detect the Charge 3. Trying all steps given but still failed until today (almost 3 days trying all the steps). I'm using Note 9, even I asked my friend to install on his Iphone 11, still facing the same issue.
Is it the Charge 3 bluetooth is too weak to detect? Kindly advise
01-13-2021 08:21
01-13-2021 08:21
@izzy73 It's good that the community is growing!
Let me help you with this and thank you for troubleshooting this issue. You don't mention which steps you followed exactly so I suggest you try the following:
Let me know how it goes.
01-14-2021 00:48
01-14-2021 00:48
Trying the step given..still didn't work..when i'm connecting to bluetooth, this message appear: Couldn't pair. Check the settings for this device and try again.
01-17-2021 10:49
01-17-2021 10:49
@izzy73 are you trying to pair it from the bluetooth settings area on your phone? The link is manages from the Fitbit app, you can't setup the tracker from the phone but need to use the Fitbit app for this.
Keep me posted.
01-17-2021 11:49
01-17-2021 11:49
I've tried every step given also. Charge 3 will set up on app and pair no problem but will not sync with my s20 5g at all
01-17-2021 22:00
01-17-2021 22:00
Hi Alvaro
I tried using the Fitbit App but still the same. unable to detect bluetooth.
any idea?
01-17-2021 23:22
01-17-2021 23:22
Hi
I've also tried all the steps including deleting app and telling phone to "forget device". Now when I re-install the app it's not even coming up with the message to pair phone & tracker. Can't see anywhere on the app to tell it to pair. This is really frustrating. Phone can't even "see" fitbit now in bluetooth settings.
Fitbit version is 28.20001.88.11
iOS version is 14.3
Fitbit App is 3.36 (1013)
Please advise - Thanks
01-18-2021 09:48
01-18-2021 09:48
@GILLYJONES85 Welcome to the Fitbit Community!
Thank you @GILLYJONES85 @izzy73 @Beth73 thank you for taking the time to troubleshoot this issue. @GILLYJONES85 @Beth73 I have created a ticket so our Support team can further assist you via email.
@izzy73 I noticed that you already have a ticket so keep working with the team to find a solution.
Keep me posted.
01-18-2021 10:38
01-18-2021 10:38
I’ve been having similar issues. Charge 3 will not connect to phone, but if I restart my phone it will connect. It only connects that one time and then I have to restart my phone again the next time I walk. This has been going on for sometime. I would appreciate any help.
01-18-2021 14:37
01-18-2021 14:37
01-19-2021 11:26
01-19-2021 11:26
Hi i have not heard from anyone? im using fitbit 28.20001.88.11 , app 3.36.1, android 11. please can you help? it will no longer connect to phone with app even though bluetooth is being picked up
01-19-2021 11:48
01-19-2021 11:48
My Charge 3 is behaving the same way. All steps tried. Nothing has worked yet.
01-19-2021 15:05
01-19-2021 15:05
01-19-2021 16:21
01-19-2021 16:21
Try uninstalling and reinstalling the app. I was having the same issue and that fixed it.
01-19-2021 16:22
01-19-2021 16:22
01-19-2021 16:24
01-19-2021 16:24
I replied to a couple posts above, but try uninstalling and then reinstalling the app. This issue has arisen for me before and an uninstall/reinstall and/or update usually works.
01-19-2021 22:25
01-19-2021 22:25
Hi ive done that several times it still doesn't work.
01-20-2021 10:27
01-20-2021 10:27
01-20-2021 11:46
01-20-2021 11:46
I'm using a s20 on android 11. Ive literally exhausted every avenue and still have not heard from fitbit.
