10-14-2018
13:11
15:06
10-14-2018
13:11
15:06
When trying to change clockface on charge 3 message says some applications did not finish installing . We are unable to update / install one or more apps please try again
10-15-2018 15:24
10-15-2018 15:24
@Lou1969 Welcome to the Fitbit family! Thanks for taking the time to share the experience you are having while changing clock faces. Thanks for sharing all the details about this.
Fitbit is currently working to resolve this and hope to have a fix soon. Be sure to keep your Fitbit device and app up-to-date to ensure you receive the quickest resolution.
In the meantime, I'd recommend performing a restart on your Charge 3. Then, try to change the clock face once again.
Keep me posted!
10-15-2018 17:19
10-15-2018 17:19
Exact same problem here. 😒
10-15-2018 19:50
10-15-2018 19:50
I've been trying to change my clock face for two days. I've rebooted my charge 3, tried to chaget while it was charging and while away from the charger It still says problem, try again later after 15 minutes of attempting to download the new face
10-15-2018 23:45
10-15-2018 23:45
10-15-2018 23:46
10-15-2018 23:46
10-15-2018 23:48
10-15-2018 23:48
10-16-2018 00:16
10-16-2018 00:16
Yes!! That worked for me as well!! Awesome!! Thanks!!
10-16-2018 07:03
10-16-2018 07:03
10-16-2018 09:07
10-16-2018 09:07
AndyCK as soon as I updated my Fitbit app on my iPhone my clockface on my Charge 3 updated. So not the iOS update itself, but the Apple Fitbit app. I just went into AppStore updates and sure enough, my Fitbit app needed updated.
10-16-2018 09:12
10-16-2018 09:12
11-28-2018 18:51
11-28-2018 18:51
I have an Android phone. I can not change the clock face. I have rebooted my phone and still says installion fail.
11-28-2018 19:20
11-28-2018 19:20
Thanks the re-start suggestion worked. When I came back from health club I noticed I couldn't swipe to look at my work totals. I thought that battery was low so I charged it. When I got back from work problems was still there. I looked up the trouble shooting and went to community. Back on track.
12-02-2018 15:17 - edited 12-03-2018 14:51
Android phone. Same problem. Been trying to get any clock face for weeks. I’ve been walking around with the “Clock error Go to the Fitbit app and try another clock” lighting up. I tried all clock faces and rebooting/reinstalling app/updating. It updates stats, but tells me it’s not connected. Today, I noticed that it changed/deleted my exercise shortcuts. No hikes, but 3 pilates! I’m so disappointed with the Charge 3 and will probably send it back and stick with Charge 2.
12-18-2018 06:39
12-18-2018 06:39
My Charger 3 says application not finished installing and not it only shows horizontal bar.
It is not responding now.
Please help.
12-27-2018 03:06
12-27-2018 03:06
Hi
Mine is doing the same.
12-27-2018 03:21
12-27-2018 03:21
12-29-2018 08:17
12-29-2018 08:17
01-05-2019 01:25
01-05-2019 01:25
Its three months since this post - when will there be a fix?
01-14-2019 13:37
01-14-2019 13:37
I got the Fitbit Charge 3 in December and I tried changing the clockface. It worked once. Then I tried to change it back to what I had and the "not finished installing" message keeps coming up on my app. I can't stop it from installing. I have tried re-setting my Fitbit. I have removed the Fitbit from the app and re-installed it in the app. Nothing seems to work.
Any help is appreciated.
