07-01-2021
16:43
04:10
WilsonFitbit
07-01-2021
16:43
04:10
WilsonFitbit
My Fitbit died but I got a new one. Yippie! I was very thankful. And life went on.......Then I had to get a new laptop. Only to learn my Fitbit would not work since Fitbit decided to change how we get the data. Unless I use a phone I can't sync data with my laptop...... I am furious that without warning you decide the data needs to go to a phone..... My phone is for work only so thanks for nothing. I want it on a laptop like I had but nope can't do what makes sense.
Moderator edit: format/subject for clarity
07-01-2021
17:49
04:04
WilsonFitbit
07-01-2021
17:49
04:04
WilsonFitbit
i just fired up the old laptop.... can't down load anything from fitbit...... even with a fob....
Fitbit you need to fix this without using a phone!
Best Answer07-02-2021 04:09
07-02-2021 04:09
Hello @PriscillaC. It's great to see you around.
I'm very sorry for any inconvenience caused and thank you very much for taking the time to provide your feedback. Please note that any feedback posted in the forums is always welcome as it helps to improve our products, services and overall environment.
On a side note, I'd like to let you know that newer devices like the Ace 3, Ace 2, Aria Air, Charge 3, Charge 4, Inspire 2, Sense, Versa 2, and Versa 3 - aren't supported on Windows and require a compatible Android phone, iPhone, or iPad.
For more information about supported devices and operating systems, please see www.fitbit.com/global/us/technology/compatible-devices. Thanks for your continued patience and understanding.
See you around.
11:53
04:40
WilsonFitbit
07-04-2021
11:53
04:40
WilsonFitbit
And this is the point.... no warning nothing Fitbit decides to end the use of a device because you want it on a phone.... this is the problem..."aren't supported on Windows and require a compatible Android phone, iPhone, or iPad. " If I'd been informed of this before I got the replacement I would not have gotten it. So I have a non working device now. It was working on the old laptop but not any more. you all should be ashamed at forcing the use of a phone. you need to have a patch created to allow people to use the devices they have.... you know that old customer service thing. I have a brand new device that with out warning fitbit changed and in doing so the method I was using was shut off
It is clear no one really cares about the customer
Moderator edit: word choice
Best Answer07-05-2021 04:43 - edited 07-05-2021 04:45
@PriscillaC Thank you very much for your reply.
I understand how you are feeling and appreciate the feedback provided. Please note that our team is always working to enhance your experience and your feedback and comments are very appreciated, since these are a big part of that process.
See you around.
