01-01-2025 18:41
01-01-2025 18:41
Hi - I'm the original owner of a Charge 3. It connects to the Fitbit app on my phone, says it's fully synched, battery is full and responds with vibrations when pressing the side button. But the screen won't turn on. I've tried changing the clock face through the app, connecting it with the charging cable and doing the various restarts suggested in the forum but nothing works to get the screen on (no smiley face, no battery icon, nothing). The firmware version is 28.20001.88.11 and there is no option in the app for me to update this to a different version. Please help!
01-15-2025 11:01
01-15-2025 11:01
@pommier , A warm welcome to the Community! Thank you for your message.
Support informed me that you already contacted them.
They mentioned, that you should have received an email with instructions.
If you cannot find the message in the Inbox, please check the spam/junk folder. Sometimes our messages are redirected there.
01-16-2025 08:28
01-16-2025 08:28
Hi fellow Fitbit Charge 3 owner I took am one of the older purchases! I've had my Fitbit Charge 3 for over 8 yrs a long time my son bought it for me and I have loved it! It has worked amazing under the management of the owner Fitbit but since Google took over and changed software it's nothing but problems! Mine is fully charged with black screen won't indicate battery level on the screen, can't see any thing just vibrates! I've followed all your unhelpful instructions it's tracking steps when I'm not even wearing it! Thought it was hacked changed password same thing so not impressed never buying a Fitbit again have to buy new Smartwatch be cause I'm fed up trying fix this! Good luck fellow owner I hope you have better luck!
Best Answer01-20-2025 07:06
01-20-2025 07:06
I have the exact same problem! Did you find a solution yet?
Best Answer01-21-2025 15:36
01-21-2025 15:36
Me Too, Can anyone assist??
Best Answer01-22-2025 08:46
01-22-2025 08:46
@SunsetRunner @Jezzy1980 @Shikera2024 , Thank you for your messages and for your reports.
If you haven't done so yet, please contact Support.
Fill out the form, you'll see some articles recommended.
Then you'll see the options to contact Support.
