08-30-2021
09:31
10:07
CindyMFitbit
08-30-2021
09:31
10:07
CindyMFitbit
Continually goes to sleep and doesn’t stay bright. Need to reset brightness and wake all the time
08-30-2021 10:03 - edited 08-30-2021 10:34
Hi @Lpdt. Welcome to the Fitbit Community! It's great to have you here!
Thanks for the details shared about the inconveniences that you have with your Charge 3 and for adjusting the settings. If your tracker goes to sleep mode by itself, I recommend performing a restart, for this, you can see the instructions here. If that doesn't work, you can try a long restart by following the instructions bellow:
Hope this helps.
Best Answer08-30-2021 10:22
08-30-2021 10:22
Your first option/answer for short restart was not in English. Not sure what language but not English and not helpful.
Best Answer08-30-2021 10:42
08-30-2021 10:42
@Lpdt Thanks for your reply.
I'm sorry for the inconvenience with the link. Please try to use this one and if the process does not work for you, please contact our Customer Support so they can provide additional assistance with this.
See you around.
