02-16-2022
08:02
08:58
AndreaFitbit
02-16-2022
08:02
08:58
AndreaFitbit
Hi, I have been here before, possibly 18 months you may or may not remember.
I am having the exact same problems with my fitbit and can not read the screen, especially outside. Totally useless, are you able to help.
Plus it's stop vibrating messages or milestones
Moderator edit: Updated subject for clarity.
02-16-2022 08:43
02-16-2022 08:43
Hi @ChrissyX these are the community forums, not customer support, but you can find your original post here - click to read. You didn't respond to the moderator at that time. I've asked one to stop by to assist you.
02-16-2022 09:07
02-16-2022 09:07
Thanks for getting back to us @ChrissyX and for the heads up @Odyssey13. I'm sorry to hear your Charge 3 screen is dim and that it's no longer vibrating.
To fix these issues I would recommend restarting your tracker:
You can restart your tracker from your wrist. Open the Settings app and tap: About: Reboot Device.
If your Charge series tracker is unresponsive: .
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
