10-17-2018
13:35
15:06
10-17-2018
13:35
15:06
Having used my new charge 3 for less than a week, I started having issues today. When I took it off my hand, the green light at the back didn't stop flashing. I couldn't turn it on with touchscreen. I thought maybe battery has gone flat and I plugged in the charger, it vibrated, restarted it and got smiley face. It was ok for few hours and then it started vibrating non stop until it died and turned off. I was unable to switch it on since then. It doesn't charge, doesn't vibrate when trying to connect to the charger - but it gets very hot after leaving it for few minutes on the charger. I followed instructions to try to restart it but no luck. Has it just died permanently or is there anything I can do?
10-17-2018 15:37
10-17-2018 15:37
Same issue with mine, barely had it three days. Hope they fix this issue soon!
10-18-2018 07:31
10-18-2018 07:31
Welcome on board @Azurite, it's nice to see you around the forums! Thanks for already troubleshooting this inconvenience with the Charge 3 not turning on, nice way to go!
Since you've exhausted all the steps in order to fix this, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps.
Thanks for jumping in here @CAlderman! I was about to create a support case on your behalf too, but I've seen that you chatted with our team already. Please keep an eye on your inbox for updates.
If there's anything else I may assist you with, let me know.
10-18-2018 10:36
10-18-2018 10:36
Hi MarreFitbit:
Please add me to the opening of a case file. I have the same problem. Half way through the second day, I no longer could get anything to pull up on my screen. I am a high school teacher and was tracking my steps while still at school before heading home. The Charge3 stopped recording and/or syncing with my iPhone app towards the end of the school day.
Since I am new to using a FitBit and thought I was just not swiping it correctly, I had my daughter, that is an experienced FitBit User of the Alta HR check it out. She did all of the usual troubleshooting tips. It stays black, doesn't appear to be charging even utilizing two different ports that work for her FitBit, and the only indications of any "life" to the Charge3 is the flickering green bar on the back side.
10-19-2018 07:08
10-19-2018 07:08
I have the same issue this morning. It died for no reason, fully charged, after a week or less of use. And the green light on the back is flashing continuously.
10-19-2018 07:37
10-19-2018 07:37
10-25-2018 15:38
10-25-2018 15:38
Just had this problem with mine also. I’ve had it for 2 weeks. What are the steps to fix it?
10-25-2018 15:41
10-25-2018 15:41
10-25-2018 16:33
10-25-2018 16:33
10-26-2018 04:09
10-26-2018 04:09
Update to the issue: customer services contacted me and asked to return the fitbit and they will replace it as I have exhausted all the steps to fix it and none of them work. Just to be more precise, I had 2 fitbits charge 3 - one is mine, the other one was a present (and that's the one not working). Hopefully new tracker will arrive soon!
10-26-2018 05:17
10-26-2018 05:17
I am having the exact same issue and did all the troubleshooting steps. Completely dead and won’t charge after only having it for 2 weeks.
10-30-2018 17:16
10-30-2018 17:16
I too am having the same problem. This is very frustrating since my Charge 3 is basically new. Please help!
10-30-2018 17:38
10-30-2018 17:38
10-31-2018 02:36
10-31-2018 02:36
10-31-2018 02:54
10-31-2018 02:54
10-31-2018 03:20
10-31-2018 03:20
I have the same exact problem can you please help me with that as well?
10-31-2018 14:27
10-31-2018 14:27
I got my Charge 3 last week. Wore it successfully until today when it went dark out of the blue, charged at 70%, and won't turn on again. So frustrating. We live out of the US and had to have a friend bring it over. Now what?
11-01-2018 02:13
11-01-2018 02:13
11-01-2018 05:33 - last edited on 02-21-2020 14:32 by LiliyaFitbit
Put the Fitbit in the charger and hold down the button on the side for 8 seconds. A smiley face should show up and it should reboot
11-09-2018 07:56
11-09-2018 07:56
Just bought the charge 3, restarted by holding the button for 8 seconds. A happy smiley appears after which screen turns black. After a while, the sad smiley re appears. Please let me know if there is a fix for this one.
