09-08-2020
13:16
17:50
09-08-2020
13:16
17:50
My charge 3 will not let me increase the brightness to a level I can see. Very dim display, unable to read. Any suggestions?
09-22-2020 08:23
09-22-2020 08:23
I went to settings and brightness was the first thing that came up. It said Dim so I swiped and it went to Normal!
Never knew this was there or how I changed it.
Best Answer09-22-2020 08:37 - edited 09-22-2020 08:38
@Kristy72 - I had the same issue and didn't see how to fix it until today. These are the instructions to fix from the tracker (can't do it in the app from what I can find). You need to adjust the brightness - it's not related to the Sleep mode like many of us thought.
I did this and went to "normal" and it worked again! Hope it works for you!
Best Answer09-22-2020 10:45
09-22-2020 10:45
Best Answer09-22-2020 10:51
09-22-2020 10:51
I have those same steps numerous times and it hasn't resolved that issue of a dim display and streaks on the bottom of the display. All of this began happening after updating the firmware. Now I have to charge every 2 days instead of once a week. I have seen plenty of other people having the same issues I'm having....has there been anything from the developers?
09-22-2020 10:58
09-22-2020 10:58
HI, I have the same problem, but have just had an online chat and Im being sent a new one in 7 days. So it would be worth reporting yours, its infuriating quite honestly, but anyway, at least I dont have to buy a new one !
Best Answer09-22-2020 11:13
09-22-2020 11:13
Hello. I tried the steps above to turn off my device. My device did not vibrate at all. I got a series of dashes and then it shut down. I removed the device from the charging cable and then plugged it back in. When I did that, I did get the smiley icon and t did go on; however, I still cannot read the screen, and I cannot tell how full the battery is.
Best Answer09-24-2020 07:32
09-24-2020 07:32
Where can I chat with someone for that.
Best Answer09-24-2020 14:57
09-24-2020 14:57
Best Answer09-24-2020 15:01
09-24-2020 15:01
09-24-2020 16:33
09-24-2020 16:33
Ricardo,
We have the same dim face on my wife's Charge 3. I have tried the "Smile" short restart process above, but no change.
I cannot get the Charge 3 to do the long restart process. I hold the button down for 15 seconds. By that time the smile disappears. Then it shows the normal clock face. And nothing else happens. I have also held it down for about 30 seconds after that. Still no battery icon. Nor any vibrations.
Jim and Brenda Cornell
09-24-2020 16:41
09-24-2020 16:41
Swipe left from clock face to Settings. First one is brightness.
Best Answer09-26-2020 22:36
09-26-2020 22:36
Best Answer09-27-2020 01:31
09-27-2020 01:31
Thankyou for that info, it's solved it
Best Answer09-27-2020 05:56
09-27-2020 05:56
But you have to be able to see the clock face to do anything. Do they deliberately get us to download updates to make the things not work so we have to buy new ones? Seems unbelievable but with so many having this problem and Fitbit not prepared to do anything to help that doesn't involve being able to see the screen it does make me wonder.
09-27-2020 07:51
09-27-2020 07:51
My Charge 3 display also went ‘dim’ today. 😞
09-27-2020 07:52
09-27-2020 07:52
This unfortunately did not fix the problem. Now what?
Best Answer09-27-2020 07:54
09-27-2020 07:54
My FitBit is only a few months old ! ☹️
Best Answer09-27-2020 08:01
09-27-2020 08:01
I feel the same way. What's the guarantee from fitbit that if I purchase another one it won't do the same thing?
Best Answer09-27-2020 08:45
09-27-2020 08:45
Mine was working fine until I was told it needed updating cant see anything now it's so faint
09-27-2020 08:52
09-27-2020 08:52
Tried this made no difference
