09-08-2020
13:16
17:50
09-08-2020
13:16
17:50
My charge 3 will not let me increase the brightness to a level I can see. Very dim display, unable to read. Any suggestions?
10-17-2020 11:25
10-17-2020 11:25
Was this due to recent update? Mine did the same thing.
Best Answer10-17-2020 11:33
10-17-2020 11:33
Try turning off sleep mode. It fixed mine and there are a lit ik f people with the same problem since the last update.
Best Answer10-17-2020 11:37
10-17-2020 11:37
Once you have tried the reset/ restart described above and the Charge3 is still dim try this.
1) Go somewhere very dark. A closet may work.
2) Press side button. On my Charge3 the time appears ( may require multiple presses to get to the time display depending on where your screen is at.
3) Swipe left. On my Charge 3, swiping 4 times took me to the settings screen.
4) Tap on settings ( The 3 lines with circles in different locations on each line )
5) 2 settings will appear. The top of the screen is for Brightness. Tap once on this to scroll to the next brightness setting.
6) There are 3 Brightness settings, Normal, Auto, and Dim. Normal works well for me. I doubt if anywhere an engineer has described Auto.
7) Pray that one day Fitbit will decide to publish these methods for their plethora of watches or hire an engineer to standardize things to retain their customers that flee in frustration at the bafflement of Fitbit attempting to encourage them to buy yet another watch.
😎 Get outta the closet! People are talking about your behaviour!
10-17-2020 13:04
10-17-2020 13:04
Same problem here - the light is so dim I can barely see anything. I did the steps above and it didn't help at all. What else do you have?
Best Answer10-17-2020 18:14
10-17-2020 18:14
OMS! Had same issue. Did everything. Nothing worked. Then saw something about screen on sleep. I tapped on that and, wellah, bright screen. i never set it to sleep. Never knew that was there. Learn something new every day. ps...when I went there, it didn't appear the screen was on sleep but I tapped it anyway, bright screen!
Best Answer11-02-2020 08:33
11-02-2020 08:33
Ha! These steps worked perfectly! I had been struggling with the dim screen for 2 days. Finally logged into my laptop and downloaded the Fitbit app to get help. Thanks so much!!!
Best Answer11-25-2020 17:33
11-25-2020 17:33
This is the best of all 500 comments I've read on this obvious problem. You gave clear consise instructions (which way to swipe(left) what to look for (settings). None of the other suggestions worked (reboot, restart etc)
Thanks for your suggestion. I'm definitely going to look at an apple watch as a better solution.
Best Answer12-06-2020 15:17
12-06-2020 15:17
Done it, nice bright screen again.
Best Answer05-19-2022 19:53
05-19-2022 19:53
The programmers dimmed the screen to sell more gadgets. This sucks.
There has to be a means by which consumers can stop this malpractice.
Best Answer05-19-2022 19:56
05-19-2022 19:56
Bright still did not allow me to read the tracker in a grocery store.
Someone screwed up the program intentionally.
05-20-2022 14:00
05-20-2022 14:00
Mine is exactly the same…. I’ve just restarted it with no improvement 😩
14:17
13:29
AndreaFitbit
05-20-2022
14:17
13:29
AndreaFitbit
Thank you …. I’ve fixed it 👏🏻👏🏻👏🏻
I swiped left on my device to the end and went to settings . My screen was set to dim so changed it & also scrolled down and turned sleep mode off too to be doubly sure … hope this helps
Moderator edit: updated post.
05-20-2022 17:19
05-20-2022 17:19
