11-22-2020 21:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-22-2020 21:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
The screen on my charge 3 is super dim. I struggled to get to settings and toggled the screen between normal and auto. I can't see anything when it's on auto... it's not on sleep mode either. Is the light dying?
11-22-2020 21:49
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-22-2020 21:49
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Having the same issue, any fixes for this issue?
11-23-2020 07:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-23-2020 07:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@Pep88 @Jrappbagel Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 3 screen being too dim and thank you for checking your tracker's settings. Try restarting your tracker by doing the following:
- Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
- Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
- Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display.
- Press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
- Disconnect your tracker from the charging cable.
Let me know how it goes.
11-23-2020 09:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-23-2020 09:09
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi Alvaro,
I tried that, and it did not work.
11-23-2020 09:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-23-2020 09:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
still very dim,cant really see anything on the screen, any other thoughts?
11-23-2020 09:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-23-2020 09:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I’m also having this issue and the solution offered did not work.
11-23-2020 10:02
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-23-2020 10:02
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I had the same issue. No solution other than Fitbit telling me my device is defective, and since it is out of warranty, I would have to buy a new one. They offered a 35% off code which I cannot use on their website. This is my second defective Charge 3.
11-25-2020 16:23
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-25-2020 16:23
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@AlvaroFitbit So I guess since you haven't responded in the last 72 hours, this was your only solution?
I can now barely see anything on the Fitbit in the dark. It's just over 1 year and this should not be happening....
12-01-2020 07:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-01-2020 07:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Same problem. Did the reboot and it is still really dark. Can't see anything. Is there any other solution, or just consider it dead?
12-06-2020 22:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-06-2020 22:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Need to them go to settings and toggle from dim to normal.
12-06-2020 22:08
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-06-2020 22:08
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Need to then go to settings and toggle dim to normal
12-08-2020 13:57
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-08-2020 13:57
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@RDAPHD you get an A for effort and an F for execution. 😜 As stated in the topic, birtghtness set to normal, not dim or auto. Also sleep mode isn't on. Basically the light started to dim over the last couple weeks. I can't see anything on it anymore, even in the dark in the room.
01-24-2021 17:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-24-2021 17:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Same problem here, too.
05-27-2023
09:35
10:24
WilsonFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-27-2023
09:35
10:24
WilsonFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Didn't work. I've tried this. Fitbit support couldn't (or wouldn't) help me. Should be a simple instruction (happened a couple of years ago), but all rep wanted to do was to have warranty team check it.
Same problem. Last time I had issues and I went to a couple of stores, they recommended forgetting Fitbit and switching to Apple watch. I just want a basic tracker that works, not a large watch.
I did that but it didn't hold.
Moderator Edit: Merged posts
