09-07-2020
06:27
09:18
AlvaroFitbit
09-07-2020
06:27
09:18
AlvaroFitbit
Hi!
Two weeks ago, i received the new Firmware 28.20001.88.11 for my Charge 3.
The Upgrade worked fine, but since the Installation, the Brightness of the Display is very, very low!! Even in dark rooms it's hard to see the displayed Information. I tried the Display settings, but the offered Options are: Low, Normal, Auto. There os no Bright Option! And the Light Sensor seems to be inactive. I switched to a large Clock Face to see at least the Time. What else can I do to get a better Display?
Kind regards from the Cat
09-07-2020
08:06
20:40
EstuardoFitbit
09-07-2020
08:06
20:40
EstuardoFitbit
@melcat Unfortunately, "normal" is the brightest setting. I'd recommend you try restarting your Charge 3 a few times to see if that fixes it. If not, you may want to reach out to Customer Support. You should be able to see your screen in a dark room or even a well-lit room. It could be that something is wrong with the display.
Best of luck!
09-10-2020 14:30
09-10-2020 14:30
Thanks for your reply, @Heather-S. Unfortunately, I could not solve the problem.
The Upgrade made the Charge 3 useless for me. I switched to another Tracker which provides a bright and sharp display.
I hope that Fitbit will recognize this problem which affects a lot of Charge 3 users and provides a Bugfix soon.
11-09-2020 02:59
11-09-2020 02:59
I have the exact same issue. It's been bothering me for a few months now. Since the upgrade to 20001.88.11 it's almost impossible to read anything that my Charge 3 HR displays..
11-10-2020
09:20
10:17
11-10-2020
09:20
10:17
@melcat Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 3 screen being too dim. Start by checking that your tracker isn't in Do not Disturb or sleep mode by long pressing the button. Also restart your tracker by doing the following:
Let me know how it goes.
11-10-2020 10:14
11-10-2020 10:14
Many thanks for your message. I tried this Steps several times, unfortunately without luck. The Screen is still dimmed.
I followed many threads in this Forum with a similar problem. Maybe, the last Software Upgrade is s source for this problem. At least, many users experienced the same problem when they upgraded their Charge 3 to 1.88.11.
Sadly, my Charge 3 is useless at this time; I cannot read the screen, even indoor. As a result, I switched to another Fitness tracker.
Maybe, Fitbit will find a solution for the problem, I will happily switch back to the Charge 3.
Kind regards, Cat-Friend (meaow)
11-10-2020
10:24
10:18
11-10-2020
10:24
10:18
@melcat meaow to you too! And thank you for your update.
This isn't the experience we want for our users so I have created a ticket with our Support team. They will reach out via email to further assist you and see what options they may have for you.
Keep me posted on the results!
11-10-2020 12:03
11-10-2020 12:03
this has happened on 2 of my Charge 3's. there is a setting for the "brightness" of the screen. what is happening is it keeps reverting back to auto. Once in auto it keeps the screen dim. I was able to change it once back to a higher level of brightness, but it has just resumed to the unreadable dim mode and i can't seem to change it back this time. Fitbit staff does not ever respond with how to correct this "setting". i spent hours going through thier useless re-starts and resets, etc. Finally telling me I am out of warranty so here is a discount for new one. It does not need to be replaced. The problem is it is changing a "setting" and the system does not let us change this setting back to normal. I think they just want us to replace them. Very unethical and I will never buy another fitbit again.
11-10-2020 12:06
11-10-2020 12:06
Can you please post the solution from the support team here? It’s obvious this is huge problem from the number of complaints filed in this forum with the same issue. It’s definitely an issue with the last upgrade. Seems like your support group should be able to roll out another firmware upgrade (even if it’s going back to the previous version until this is resolved). Like everyone else my Charge 3 is now useless and I’m not getting credit for my steps with my insurance carrier ☹️
11-10-2020 12:29
11-10-2020 12:29
and I have the same problem. I can't read my screen at all hardly. Very disappointing. I like the product but if it has these bugs, I wont replace it with another fitbit. My last fitbit got lines across the display and gradually disappeared. It was replaced. Very sad now that this one is doing a variation of the problem and none of the fixes work. Haven't seen one person say that the fixes recommended have helped, yet the moderators keep suggesting the same thing.
05-23-2021 18:47
05-23-2021 18:47
same issue here! the auto level does allow the Fitbit to be brighter than the normal mode, but only in very bright environments. Fitbit should add a 'high' brightness mode. if they have to add a warning about decreased battery life, so be it.
