08-20-2018
08:50
15:47
08-20-2018
08:50
15:47
Will the Charge 3 have the ability to have the screen brightness adjustable? During the night it would be great if the display does not mimic a high intensity flashlight and scald retinas, and during the day it should be bright enough to view in full sun.
11-01-2018 18:48
11-01-2018 18:48
@littlesprout hold on the left button to get to the brightness settings.
07-19-2019 13:23
07-19-2019 13:23
My Charge 3 very rarely brightens. I quit trying to see time or date or responding to vibrate indicators. I cannot read the face in the sunlight or at night. Every once in awhile it shines brightly in bed when I roll over.
07-19-2019 13:25
07-19-2019 13:25
I agree with you and I have a Charge 3.
01-28-2020 10:34
01-28-2020 10:34
I have the same bad experience with display brightness. When I first used it I was impressed with how bright it was but now a few days it's dim when on the "normal" or "auto" settings and completely unreadable on the "dim" setting. It is still more than half charged so I can't believe it's the battery running down. I can't find a way to get it back to where it was when I first opened the box. Any ideas how to get it back up to decent readable brightness?
01-28-2020 11:36
01-28-2020 11:36
I am having the same issue. Would be nice if the brightness was able to be set manually instead of automatically. I can't see anything on the screen just sitting in a normally lit room, but at night when I move just right, it lights up the room. I thought maybe it needed charged, but when I plugged it in, it was at 87%. Arghhhhhh……..
01-28-2020 12:38
01-28-2020 12:38
01-28-2020 14:20
01-28-2020 14:20
01-28-2020 18:25
01-28-2020 18:25
01-28-2020 19:21
01-28-2020 19:21
06-06-2020 03:27
06-06-2020 03:27
I just had to switch back to my Versa from the Charge 3. Couldn’t see the display at all while running. Love the size of the Charge 3, but the display is unusable outdoors.
06-06-2020 13:55
06-06-2020 13:55
06-06-2020 14:00
06-06-2020 14:00
I agree - such a hige disappointment and wish I had just stuck with my Charge 2
06-06-2020 15:45
06-06-2020 15:45
08-24-2020 17:20
08-24-2020 17:20
Due to the pandemic I have been walking and bicycling more and I have been out both during the day and in the evening. It seems to me that the brightness setting is only applicable to the main display. When in exercise mode, on a sunny day the display seems to only be using the dim setting even if auto or normal have been selected previously in settings. I’m out of the warranty period so there is nothing that Fitbit support will do for me. I had a band problem with my Fitbit Charge 2 out of warranty and Fitbit wouldn’t do anything for me at that time. Luckily for me, at the time the Costco return policy for electronics was more liberal than it is now and they gave me credit for my Charge 2 and then I bought the Charge 3.
09-23-2020 07:54
09-23-2020 07:54
Yes, have had my charge 3 for about a year now and it has three settings for brightness; dim(totally useless), normal (okay indoors and inshade without sunglasses) and finally auto, (switches from dim to normal). If you're looking for a bright display to read outside in the sun, don't waste your time and money on the charge 3!
10-04-2020 13:28
10-04-2020 13:28
Really, unless the tracker has an e-paper or LCD dont plan on being able to read in direct sunlight or plan on only getting a few hours of battery life.
10-04-2020 21:29
10-04-2020 21:29
On the charge 3 swipe
to settings. There is Choice for brightness, dim, bright and auto. I was happy to find it because mine was on dim
