11-29-2018
10:28
14:34
11-29-2018
10:28
14:34
My Charge 3, which is about 6 weeks old has developed a dead horizontal line about 1/5 of the way down the screen. It's like a dead pixel, but extends right across the screen and always remains black. It's not too much of a problem; info is still easy to read, but it's clearly a fault and may get worse. I intend to return it for an exchange, but am posting to let other users know about this issue.
10-14-2019 17:58
10-14-2019 17:58
Best Answer10-14-2019 20:48
10-14-2019 20:48
I had total success when my second fit bit starting acting up and they've been great. Me. Really supportive
Best Answer10-15-2019 14:25 - edited 10-21-2019 17:48
Hi @SunsetRunner, @KimD. and @Kathy23. I'm glad to see you here again.
@SunsetRunner, thanks for confirming that you've tried changing the clock face and performing the long restart with the steps suggested before. You did a good job and since your Charge 3's screen is still not working, I've gone ahead and requested a case on your behalf. You'll receive an email with more details shortly.
@KimD., thanks for sharing your experience and I'm sure your post will help others that are having the same issue with their Charge 3 devices.
I'll be around, keep me posted!
10-17-2019 10:40
10-17-2019 10:40
Hi,
For 3 days I have gone through every step you have offered others to try and fix my Fitbit Charge 3. I believe everything is functioning properly with the exception of the diplay screen & bluetooth. I can't restart the watch itself, because I can't see any of the information.
I have done the following with absolutely no luck:
1. Changed clock face (5 times)
2. Plugged in charging cable, held sides of fitbit for 15, taken of cable, put it back on...etc.
3. Bluetooth turned off and back on
4. Un-installed app & re-installed
5. Deleted the device & attempted to re-sync, but due to not being able to see the digit code on the face of my fitbit, I'm unable to do so.
Please advise on next steps.
Thanks!
10-18-2019 13:05
10-18-2019 13:05
Hi @jenjer_2. It's nice to see a new face around the Forums.
Thanks for taking the time to troubleshoot your Charge 3 with the steps suggested in this thread. Since your Charge 3 screen isn't responsive, I've requested a case on your behalf so our Support team can give you a hand. Please keep an eye on your inbox, you'll receive an email from them shortly.
Catch you later! 😉
Best Answer10-18-2019 15:39
10-18-2019 15:39
Best Answer10-20-2019 18:51
10-20-2019 18:51
Hi,
I am having the same problem on my fitbit. I thought it would go away but It’s getting worse. I tried restarting it but the problem remains the same.
Best Answer10-21-2019 17:50
10-21-2019 17:50
Hi @jenjer_2, I'm glad to see you here and I'm sorry for the delay. @SunsetRunner, welcome on board.
@jenjer_2, you're welcome and hope I can see you on track soon. In case you have some spare time, I’d like to invite you to visit our Discussion Board where you will find great tips and encouragement from other members.
@SunsetRunner, thanks for letting me know that your Charge 3 is having the same behavior. You did a good job with the restart process and just to confirm, have you also try changing the clock face and performing a long restart which is different from the regular restart? If not, please given them a try as they worked for other users.
Let me know how everything goes!
10-21-2019 18:48
10-21-2019 18:48
It seems as though the line issue is a common problem. I have tried all of the troubleshooting suggestions. My problem had been getting worse over time. Any other suggestions?
Best Answer10-22-2019 01:06
10-22-2019 01:06
Best Answer10-22-2019 09:20
10-22-2019 09:20
Best Answer10-23-2019 12:38
10-23-2019 12:38
I’m having this problem done what was suggested and this is a replacement one already so it’s the 2nd time happening not impressed
Best Answer10-23-2019 15:30
10-23-2019 15:30
Best Answer10-23-2019 18:35
10-23-2019 18:35
I am having the same issues with black lines on my display. I have restarted several times. I have even let my Charge 3 die once to see if that would work. Please help.
Best Answer10-23-2019 20:59
10-23-2019 20:59
My Charge 3 that I got in January started showing lines earlier today and then just vibrated and switched screens rapidly and continuously. Now it's just showing a straight white line with two vertical black lines near the top.
It will not respond to any restart efforts.
Best Answer10-23-2019 21:02
10-23-2019 21:02
Hi Alejandro, mine also has several lines going vertically from the top to the bottom of the entire middle section of the screen as well. I have reset/restarted it several times to no avail. Due to comments I have read about issues getting it wet, i have never used it in water. I have not showered or swam with it at all. Can you assist?
Best Answer10-23-2019 22:34
10-23-2019 22:34
this has happened to my fit bit i have tried this reset but is still has horizontal lines on the display.is there any other way to get rid of the lines as it is now getting annoying. thank you
Best Answer10-25-2019 12:05
10-25-2019 12:05
Hi everyone. Thanks for posting in this thread and I'm sorry for the delay. I'll continue helping you with your Charge 3.
I appreciate you for sharing your thoughts about this issue affecting your Charge 3 devices. Our team has received your feedback as it helps us to work on our products and improve their performance. I understand how you're feeling about this, and be sure that your comments haven't gone unnoticed. For any warranty-related inquiry, please check our warranty policies here.
@Graciouskitten, thanks for troubleshooting your Charge 3 and since the issue persists I've requested a case on your behalf so you can receive further assistance from our Support team. Keep an eye on your inbox!
@Lyssa5, @SMS7777 and @audwee, I'm sorry that your trackers are experiencing these issues. You did a good job with the steps. So we can exhaust our troubleshooting, please confirm if you've tried to restart it, changing the clock face and performing the long restart in that order. I'll look forward to your reply.
@Jaci1, @Srs11 and @IamEm2019, thanks for sharing that your Charge 3 are having this behavior and the steps tried on your own. I was checking your details and apparently you already opened and our team provided you with assistance. If you have a question about their resolution, I'd recommend to reply back to their last email so you can receive more details.
See you around.
Best Answer10-25-2019 16:44
10-25-2019 16:44
I restarted it and it now has the fitbit logo (the dots are lighting up in various ways) and the number 001, with both vertical and horizontal gray and black lines on the screen.
It does not respond to any other efforts.
Best Answer10-26-2019 01:45
10-26-2019 01:45
I have the same problem! Please can you help! Not sure how to add a photo here but happy to do so if you tell me how. I have 2 dead lines through my screen.
