11-29-2018
10:28
14:34
11-29-2018
10:28
14:34
My Charge 3, which is about 6 weeks old has developed a dead horizontal line about 1/5 of the way down the screen. It's like a dead pixel, but extends right across the screen and always remains black. It's not too much of a problem; info is still easy to read, but it's clearly a fault and may get worse. I intend to return it for an exchange, but am posting to let other users know about this issue.
06-08-2020 03:29
06-08-2020 03:29
Well I cannot fault their replacement policy on this occasion. I got an option for a replacement or 50% off an upgrade.
If the original charge3 had lasted then I would consider an upgrade but I can't justify it when the first product lasted 7 months.
They will get my repeat business if the replacement I am sent doesn't go faulty.
Thoughts, whilst annoying this thread would be a lot longer if this was a universal issue so I hope my replacement doesnt have the same problem.
06-08-2020 11:55
06-08-2020 11:55
06-08-2020 13:13
06-08-2020 13:13
Can't argue with that, especially those who have had the issue multiple times on replacement devices.
06-16-2020 10:38
06-16-2020 10:38
I have the same problem. It just started today. 3 horizontal bands near the top 1/3 of the display. Resetting it did nothing. That, combined with the fact that it's a constant battle to sync it makes me wonder if I made a mistake in purchasing it. I've only had it a few months and it's been a disappointment.
06-16-2020 11:03
06-16-2020 11:03
06-17-2020 00:38
06-17-2020 00:38
Hi I have the same issue. I have reset my fitbit several times. Pleased can you advise. Thanks Carol
06-17-2020 00:51
06-17-2020 00:51
Hi I have the same issue. Please can you contact me to resolve this. I got mine for Christmas so it's only 6 months old.. thank you
06-17-2020 00:56
06-17-2020 00:56
If you have an issue I suggest you contact them directly. This is community and whilst they might see your issue and get in touch it's not a customer services page.
They were very nice. I sent them a picture. They got me to go through some checks on the phone (they have a script to follow which is not their fault and confirms everything that might fix it has been done so be patient).
Good luck
06-17-2020 01:03
06-17-2020 01:03
06-17-2020 05:09
06-17-2020 05:09
06-17-2020 06:25
06-17-2020 06:25
My Fitbit Charge 3 is doing the same thing. I reset it with no change. It is only 5 months old. See photo.
06-17-2020 06:39
06-17-2020 06:39
06-17-2020 07:02
06-17-2020 07:02
They are replacing it. You’d think a mature product would have these issues resolved already?
06-17-2020 07:23 - edited 06-17-2020 07:26
I seem to be having the same issue but my screen appears to be much worse and sometimes shows a large ! On the screen. I have contacted fitbit support a month or two ago and tried to restart process twice with no luck. I have had Fitbits since 2014 with no issues, only buy a new one when I want to upgrade. Is there anything that can be done to save this fitbit since its not that old?
Thank you,
06-17-2020 08:44
06-17-2020 08:44
06-17-2020 08:45
06-17-2020 08:45
06-17-2020 09:19
06-17-2020 09:19
06-17-2020 09:41
06-17-2020 09:41
06-17-2020 10:50
06-17-2020 10:50
been there done that mine was just over the warranty and they would only give a discount and this is my
2nd fit bit
06-17-2020 15:11
06-17-2020 15:11
