10-23-2018 09:49 - last edited on 11-17-2020 15:03 by MatthewFitbit
My screen is 'hung' on "Screen Wake" and "Notifications." I cannot seem to swipe the screen fact to any other screen, not time, or steps or anything. Any tips?
04-13-2019 02:41
04-13-2019 02:41
How do you restart the fitbit watch?
04-13-2019 09:33
04-13-2019 09:33
Welcome on board @SunsetRunner! I'm also glad to hear that changing the clock face brought the display back. Thanks for sharing what worked for you!
In order to restart your Charge 3, follow these steps:
Please don't hesitate to let me know if you need further assistance, I'm always around!
04-17-2019 13:06
04-17-2019 13:06
As of last night my display is experiencing the same issue - display is frozen on the clock screen and no touch inputs have any effect. I tried the restart steps and nothing happens. When I connect the device to a charger it doesn't show the battery icon and when I hold the left button for 8+ seconds it vibrates and goes blank but then when I release it just shows the same screen and is still frozen.
04-18-2019 08:20 - edited 04-18-2019 08:22
Welcome on board @Pittjman, it's nice to see a new member around! Thanks for taking the time to restart your Charge 3 in order to fix the issue with the screen. Nice way to go!
Since your device is still vibrating when you connect it to the charger, please change the clock face to a different one. Let's see if this does the trick! 😉
04-24-2019 03:39
04-24-2019 03:39
I have these same symptoms, but no amount of pressing on the button for eight seconds or even longer has any effect. The screen just goes dark. It is frozen with time displayed and heart rate updating sluggishly, but no blinking heart, no swipe action response, nor any other signs of activity. What’s going on? it also is also perpetually showing low battery indicator, even though I have had it on the charger now for some time.
04-24-2019 06:01
04-24-2019 06:01
04-24-2019 06:05
04-24-2019 06:05
Try going onto the fitbit app and go to the area that allows you to change the watch interface. Change the watch interface. It should unfreeze the watch. That's what l do .
04-24-2019 12:50
04-24-2019 12:50
04-25-2019 12:38
04-25-2019 12:38
Welcome to the Fitbit Community @jakdawgus! I'm glad to hear that the steps provided by @SunsetRunner did help. 😉
Please don't hesitate to let us know if you need further assistance.
04-25-2019 21:24
04-25-2019 21:24
This reset process is not working at all, after several attempts to carefully follow instructions!
04-25-2019 21:31
04-25-2019 21:31
I am not sure if your symptoms are all the same, but no reset options were working for my frozen screen, and then I tried Patrick’s advice, and it worked!! He said:
“Try going onto the fitbit app and go to the area that allows you to change the watch interface. Change the watch interface. It should unfreeze the watch. That's what l do.”
04-26-2019 04:44
04-26-2019 04:44
So what are you supposed to do when you're at work and you don't have your charger with you?
04-26-2019 05:53
04-26-2019 05:53
04-26-2019 06:26 - edited 04-29-2019 09:08
Welcome on board @Q.Hansen! Thanks for taking the time to restart your Charge 3. Since the restart did not work, I'd recommend following @jakdawgus and @SunsetRunner's suggestion. Try changing the clock face by following the steps at: How do I change the clock face on my Fitbit device?
Welcome on board @Vernicurn! If you're at work and you did not bring the charger with you, as long as your Charge 3 is syncing you can definitely change the clock face on your device.
Give this a go and let us know the outcome. We'll be around!
04-27-2019 09:30
04-27-2019 09:30
Charger 3 display has frozen. I’ve tried to restart it by plug it in and press the button for 8 seconds. Now it is completely dark and does not respond at all. I need your help!!!
04-27-2019 09:44
04-27-2019 09:44
04-28-2019 19:39
04-28-2019 19:39
I recieved a fitbit charge 3 a month ago fir my birthday. For the last couple days, my charge 3 is stuck on the notification screen and I am unable to restart, charge (it doesn't show battery charging). I've read several solutions and tried all of them, but nothing is working.. Very frustrating..
04-29-2019 09:10
04-29-2019 09:10
Welcome on board @LvLParis and @CLBoggs! I'm sorry to hear your Charge 3 display is still frozen after the suggestions you've tried.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Hey there @Q.Hansen, thanks for coming back and for helping out. I was wondering if your Charge 3 is back on track after changing the clock face?
I'm looking forward to your response.
05-30-2019 16:09
05-30-2019 16:09
I have exactly same problem. Screen frozen. Tried restart and smiley face comes on but nothing more. have restarted 3 times. This needs fixing please
06-01-2019 10:11
06-01-2019 10:11
Welcome on board @Bensington! Thanks for much for taking the time to restart your Charge 3 and for changing the clock face to fix the issue with the screen.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. I'm sure that from now on, everything should be working correctly.
Please let me know if there's anything else I may do to assist you in the meantime.
