11-10-2022
14:43
02:18
11-10-2022
14:43
02:18
Is there any way of fixing the display on my fitbit?
11-11-2022 06:36
11-11-2022 06:36
See if support can help you.
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
11-10-2022 15:06
11-10-2022 15:06
Hi @Annamarie88 this is something a Fitbit Moderator posted to another member with the same problem.
"Please make sure that the Charge 3 is not set to Sleep Mode. Take into consideration that when Sleep Mode is activated, the screen's brightness is set to dim.
If this is the case, please disable the Sleep mode. You can do this on the quick settings on your Charge 3 screen. Also, make sure to set the correct Brightness Setting, this can be found in the Setting App on your Charge 3. For more information about how to navigate your Fitbit device, please click here.
Lastly, perform a restart by following the steps in this help article: How do I restart my Fitbit device?"
Best Answer11-11-2022 00:08
11-11-2022 00:08
Best Answer11-11-2022 06:36
11-11-2022 06:36
USA: click
11-11-2022 06:41
11-11-2022 06:41
12-07-2022 22:14
12-07-2022 22:14
Remove your old Charge 3 from the Bluetooth settings on your phone.
Turn off other Bluetooth connections when not in use.
Plug it into the charging cable and open the Fitbit app.
Setup your Charge 3.
Regards,
Will
