01-13-2019
08:52
13:05
01-13-2019
08:52
13:05
I have just charged my Charge 3 and the screen has gone from black to grey with vertical stripes .I have tried rebooting and plugging the charger in again but the screen is still the same.TIA for any help
07-08-2020 07:45
07-08-2020 07:45
Same thing happened to mine. I called customer service and when through the recommended steps. When it didn’t work I was told that since my Fitbit was slightly over 1 year only (by a matter of a couple of weeks) it was out of warranty and I was out of luck. He then tried to sell me an updated model at a discount of course. I’ll just use it until it dies and then go with another brand. I’ve used Fitbit for probably over ten years. I remember when customer service was better.
07-08-2020 07:59
07-08-2020 07:59
07-16-2020 13:00
07-16-2020 13:00
This is disappointing. I was offered 25% discount, and the joke is I have to purchase the same defective C3 model! they don't apply it to C4. I'm confused really, on one hand I really liked my C3 experience when it actually worked, on the other hand I feel insulted and find it irrational to get the same model again!! I was told though that Fitbit is 'aware of the issue' and they may make it public. I insisted what it means 'make public' and whether we can expect compensation due to manufacturer's error but they did not reply.
07-16-2020 13:18
07-16-2020 13:18
07-16-2020 19:32 - last edited on 07-27-2020 19:51 by LiliyaFitbit
Yes, you have a difficult choice. Obviously they made a defective product
but they did replace mine which was under warranty. I got the same Charge 3
and this one works fine - plus i have not heard of anyone complaining about
the replacement model. The bad news is yours is not under warranty. I do
not think they will offer a higher discount than 25%. It may be worth it to
get 25% off the Charge 3 if they give a full warranty. IMO: If no warranty
....no deal.
Retired Surfer
Sent via my iPad Pro 12.9
07-17-2020 21:51
07-17-2020 21:51
Good news - Fitbit are replacing mine free of charge. This is the second one they have replaced so wonder how long this one will last.
07-18-2020 04:25 - last edited on 07-27-2020 19:51 by LiliyaFitbit
Not a good sign.
Retired Surfer
07-26-2020 16:07
07-26-2020 16:07
I followed the steps below. I few times. The screen is still grey.
Several times when I held down the button while on charge it vibrated and a happy face came on. It would NOT go through
It skips to
5.The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur. Remove the device from the charging cable.
6.The device shuts down.
7. Important: Plug the device into the charging cable again.
So I get a happy grey face one again. 😞
What now? HELP
07-26-2020 16:12
07-26-2020 16:12
07-26-2020 16:22
07-26-2020 16:22
07-26-2020 16:23
07-26-2020 16:23
In Nov mine will be two years old. 🤔How long is the warranty good for?
07-26-2020 19:34
07-26-2020 19:34
Mine is only 7 months old and just started doing this today. I've tried resetting, updating, nothing works. I don't swim or shower with mine, but I'm always wearing it. Guess I'll be calling tomorrow
07-27-2020 03:24 - last edited on 07-27-2020 19:52 by LiliyaFitbit
The question is whether or not you are under warranty. If yes quickly call
Customer Service and speak to a real person who will ask you a few
questions and probably approve a new one. If not under warranty you will be
offered a 25% DISCOUNT off a new one - the newer Charge 3s work fine but
check if it comes with a warranty. Good luck
Retired Surfer
07-27-2020 05:51
07-27-2020 05:51
07-27-2020 06:59
07-27-2020 06:59
07-27-2020 07:03
07-27-2020 07:03
07-27-2020 07:13 - last edited on 07-27-2020 19:52 by LiliyaFitbit
Decision time!
Retired Surfer
07-27-2020 07:37
07-27-2020 07:37
07-27-2020 08:46
07-27-2020 08:46
That is exactly my experience. This last time, I asked to speak to a supervisor because it was the 2nd Fitbit with the same issue….just out of warranty. When i told the supervisor this is indeed a KNOWN issue, just look at the forum comments, he decided to send me a new one at no charge, but with no warranty. They need to fix this as when it happens a 3rd time, I will go to another brand!
07-27-2020 09:56 - last edited on 07-27-2020 19:53 by LiliyaFitbit
Guess Fitbit is just waiting for Google to take over and make the big
decisions. Right now they remain in Limbo with lots of frustrated customers
and without a clear direction.
Retired Surfer
