09-24-2020
10:53
14:35
09-24-2020
10:53
14:35
The display is unreadable today, it was fine yesterday. Is this the fitbit or some central problem. I have had this fitbit for only a few weeks, it has been replaced about 5 times due to display issues.
09-24-2020 11:42
09-24-2020 11:42
Check that you are not in Sleep Mode, keeping display dim.
09-25-2020 06:37
09-25-2020 06:37
Not in sleep mode but thanks for your reply. Will contact customer support again.
Best Answer09-26-2020 07:58
09-26-2020 07:58
This happened to my Charge3 after the last hardware update. I was given a discount coupon to buy another Charge3. I didn’t use it after others were mentioning same problems on their replacement devices. I ordered an Inspire2. If this one fails I’m totally done with Fitbit. I am planning to send a letter with my bricked device back to FitBit for them to see what their brilliant hardware upgrade did to it. This upgrade turned a perfectly working Charge3 to basically a fancy Flex.
