03-04-2019 07:30 - last edited on 11-17-2020 11:22 by MatthewFitbit
My Charge 3 display is so dim that I can’t read anything unless I’m in a dark room. I can’t see anything on the display while outside in the sunlight. I’ve tried the normal setting and the auto setting. And today my display is going completely blank. I reset it and changed the clock face. The display came back temporarily for 10 minutes then went blank again.
03-04-2019 07:34
03-04-2019 07:34
Hi @LHall66 As restarting hasnt fixed the issue, I will flag your post for a moderators attention.
Helen | Western Australia
03-04-2019 10:18 - edited 03-04-2019 10:19
Welcome to the Fitbit Community @LHall66! Thanks for restarting your Charge 3 and for making sure the setting were set correctly. So, I went ahead and created a case for you with our Support team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Thanks so much for your help and for flagging the post @NellyG!
Ping me out if you need further help!
03-07-2019 10:14
03-07-2019 10:14
My charge 3 is the same way. Was bright when I purchased it but in the last week or so it has gone dim. I tried changing the settings but it doesn’t change the brightness.
05-03-2019 11:29
05-03-2019 11:29
Hi there!
Having the same issue with my Charge 3 - can't see anything on the screen, even when I set it to "Normal brightness".
Would it be able to assist me on how to fix it?
Thanks!
05-03-2019 12:02
05-03-2019 12:02
05-03-2019 13:20
05-03-2019 13:20
05-05-2019 08:20 - edited 05-05-2019 08:22
Fitbit was very good in getting mine replaced. It was under warranty. I hope yours is too.
05-17-2019 17:08
05-17-2019 17:08
I am having the same problem. Just started a day ago. I have reset the device and it has a full charge. Any suggestions?
05-17-2019 19:57
05-17-2019 19:57
05-18-2019 10:45
05-18-2019 10:45
06-27-2019 21:30
06-27-2019 21:30
Hello,
I am also having this same issue, I can only see the display in a very dark room.
My fitbit Charge 3, is less than a year old, I received it in October 2018. I have tried resetting it, changing the clock face etc.
Please let me know what i need to do!
06-28-2019 04:49
06-28-2019 04:49
06-28-2019 05:03
06-28-2019 05:03
07-22-2019 15:59
07-22-2019 15:59
My charge 3 is doing this too. Just in the past week it has gone dim and I can barely see it.
07-22-2019 15:59
07-22-2019 15:59
07-22-2019 16:02
07-22-2019 16:02
09-20-2019 08:50
09-20-2019 08:50
My Charge 3 display was not turning on after a couple of months of usage, I called Fitbit support and they sent me a replacement. Now after a few more months, still within the warranty period, I am facing the exact problem that you are - Display so dim I can't even read it indoors unless I wrap by hand around it to make a hole to look through it. Contacted Fitbit two weeks ago, and they said it is a known issue affecting a small number of customers and they cannot replace the device as it is a software problem, and that their engineers are working on a fix, but no ETA. They asked me to keep my software/firmware up to date and check after a couple of days, which I did. Called them again after 3 days, and they gave the same answer to just wait for another week and hope that the problem is resolved. I called them after a week and they gave me the same answer, and no estimated date for resolution. I am very disappointed with Fitbit.
09-20-2019 09:01
09-20-2019 09:01
09-24-2019 14:21
09-24-2019 14:21
Mine is doing the same thing since the last update. Mines over a year so I guess I’m out of luck. I like the app but the product is not well engineered or durable. I’m done with Fitbit I think.
