03-04-2019
07:30
11:22
03-04-2019
07:30
11:22
My Charge 3 display is so dim that I can’t read anything unless I’m in a dark room. I can’t see anything on the display while outside in the sunlight. I’ve tried the normal setting and the auto setting. And today my display is going completely blank. I reset it and changed the clock face. The display came back temporarily for 10 minutes then went blank again.
06-30-2020 19:29
06-30-2020 19:29
07-01-2020 23:17
07-01-2020 23:17
07-02-2020 12:05
07-02-2020 12:05
I asked my daughter for help and she discovered that I had somehow set it to dim myself. It is now working fine
Best Answer07-02-2020 14:40
07-02-2020 14:40
I have also noticed that my display is very dim. I can't read it outside and lately I have trouble reading it inside too. I have reset it, changed the settings back and forth between normal and auto but no change. It is worthless unless I have my phone with me. I have to wait for it to sync though. I basically cannot use it as a watch anymore.
Best Answer07-03-2020 01:18
07-03-2020 01:18
Best Answer08-19-2020 14:47
08-19-2020 14:47
same issue and it no longer records my sleep patterns
Best Answer08-19-2020 14:51 - edited 08-19-2020 14:52
It got so bad that I couldn't see anything anymore. I had to buy a new one. Everything else on it worked fine though. What good is it if you can't see it.
Best Answer08-19-2020 15:38
08-19-2020 15:38
I have the same problem my screen is so dim that Ona bright day you cannot read it. If I go into my setting on Fitbit it says normal. I have tried to change it but no joy, I have also changed the clock face but it is still the same. Any idea how to get the brightness back.
Best Answer08-19-2020 16:09 - last edited on 08-19-2020 19:48 by LiliyaFitbit
Yah. I gave up and took the 50% discount towards a versa. Versa is working
great.
Best Answer08-19-2020 17:49
08-19-2020 17:49
Sad to say that I had to ditch the Charge 3. It eventually would no longer maintain a charge, and failed to reboot. Mine was past warranty and I went with the Charge 4 with no problems. I also bought the insurance. My wife has a Charge 2 and never had this issue. Fitbit support seems to never respond to these. Suggest you contact them directly.
Best Answer08-19-2020 20:08
08-19-2020 20:08
Best Answer08-19-2020 20:13
08-19-2020 20:13
Best Answer08-22-2020 06:35
08-22-2020 06:35
My Charge 3 has been doing this for months and at first I thought it was just me, but then every now and again it would come back bright !! I have reset but it just went back to Dim. I made sure the setting was in normal but it’s still very fun and I have to use my phone to see the time..... How can I get this fixed please ...😩
Best Answer08-22-2020 12:39
08-22-2020 12:39
Best Answer08-22-2020 12:57
08-22-2020 12:57
**ahem** I wish I had. checked out these posts earlier. I just received my charge 3 same issue plus it doesn’t track all of my steps 😡
Best Answer08-22-2020 18:17 - last edited on 09-18-2020 18:43 by LiliyaFitbit
If new, it is still under warranty call support and apply credit to a Charge 4 which apparently has it fixed. After the dimming issue, it went further downhill. I charged mine to now get just a smiley face. It would not reboot via their process and the battery failed to hold a charge.
Regards
Best Answer08-22-2020 20:19
08-22-2020 20:19
Best Answer09-01-2020 13:22
09-01-2020 13:22
Having same issue with brightness, have tried all the usual steps and still very dim
Best Answer09-02-2020 23:35
09-02-2020 23:35
Best Answer09-18-2020 13:09
09-18-2020 13:09
I had the same issue and I was going to reset it. I took the band off and it was filthy at the band so I cleaned it up and it is bright again without the reset. Maybe it will work for you too
