10-07-2022
08:49
08:26
AndreaFitbit
10-07-2022
08:49
08:26
AndreaFitbit
My display is very dim although set to normal. The screen is so dim you can barely see the numbers on the largest clock face, which I have changed several times. I restarted it and turned it off and back on again several times to no avail. When I turn it off it only vibrates 6 times instead of 7 but still turns off. I have tried everything I read in the forums. How do I fix this?
10-18-2022 08:31
10-18-2022 08:31
Welcome to the Fitbit Community, @Damisela. Thank you for letting us know about the steps you have followed in order to brighten your Charge 3 screen.
I understand how frustrating this could be and could you please confirm that you have tried the long restart:
Keep on visiting the forums.
10-18-2022 08:31
10-18-2022 08:31
10-21-2022 02:28
10-21-2022 02:28
Just go to settings/brightness and select brightness you want Dim/Normal/Auto. It defaults to dim
Regards,
Will
11-23-2022 18:29
11-23-2022 18:29
Will, that's great IF you can see the screen to get to the settings/brightness menu. If the screen is too dim - you can't see anything,
11-24-2022 08:14
11-24-2022 08:14
Welcome to the Fitbit Community, @Biebs01. I'm sorry to hear that you can't see anything on your Charge 3 screen.
Could you please confirm that you have restarted your tracker:
See you around.
11-24-2022 18:13
11-24-2022 18:13
11-25-2022 07:10
11-25-2022 07:10
Thanks for getting back to us @Biebs01.
We're glad to hear that you're back on track.
Have a nice day.
01-24-2023 11:26
01-24-2023 11:26
Even after pressing it for 15 seconds there is no vibration. What to do?
My screen is so dim that I cannot read anything even in dark.
Please help
01-25-2023 06:59
01-25-2023 06:59
Welcome to the Fitbit Community, @Taniya. I'm sorry to hear that your Charge 3 is not vibrating even after pressing it for 15 seconds and there's no vibration.
Could you please try to change your Charge 3 clock face. Follow the instructions of: How do I change the clock face on my Fitbit device?
Let me know how it goes.
