01-23-2019
06:16
13:05
01-23-2019
06:16
13:05
Fitbit Charge 3 display not working, why? It was at 95 % charge
12-03-2019 07:39
12-03-2019 07:39
Hi
I am also having the same problem, I have reset the watch 5 times today which works initially but only for a shot period. I have also changed the clock face this has not helped either.
kind regards
Karen
12-03-2019 07:44
12-03-2019 07:44
12-03-2019 07:51
12-03-2019 07:51
It’s only 3 month old, looks like a bit of an issue from what I’ve read on here.
12-03-2019 08:06
12-03-2019 08:06
12-03-2019
13:26
06:02
JuanJoFitbit
12-03-2019
13:26
06:02
JuanJoFitbit
Surprisingly just over 1 year old - the screen started getting lines on it for around a week before this total black out happened. Really disappointed 😞
I am not buying another one as this is my second . Really liked it when working but this is ridiculous - not cheap here either!
Moderator edit: merged reply
12-03-2019 14:08
12-03-2019 14:08
Mine has stopped working this evening too. Finding it hard to try the reboot or reset as I have no display at all. Currently trying to change the clock face but now the app doesn't seem to be working.
12-03-2019 20:19
12-03-2019 20:19
12-03-2019 20:36
12-03-2019 20:36
12-03-2019 20:48
12-03-2019 20:48
12-03-2019 23:28
12-03-2019 23:28
Thanks everyone been in contact with Fitbit and was offered a replacement or 50% off another device.
12-03-2019
23:34
06:03
JuanJoFitbit
12-03-2019
23:34
06:03
JuanJoFitbit
Hello. I am having the same issues as everyone has else have been talking about and I’ve tried to do all of the things suggested and I have had no luck. Is there anything you can suggest I do? Thanks for your help.
Good morning.
i have had the same CB issues that everyone else has talked about and have tried all the things suggested. However I’m still in the same spot as I was. Is there anything you could do to help me out.
Thanks in advance for your help.
12-04-2019 08:36 - last edited on 09-06-2020 19:08 by LiliyaFitbit
I recommend contacting FitBit customer service. They will send you a new
one.
Thank you,
12-05-2019 06:19
12-05-2019 06:19
My charge3 display stopped working. I have tried all the fixes mentioned . I am pretty sure that the display just died. I actually saw it. my display was partial so I pushed the button on the side. every time I pushed the button the display got less until it was finally gone and has never come back. I have had my charge3 since July. I love it, I just wish that it still worked properly. Is this covered under warranty? can I get a replacement?
12-05-2019 06:44
12-05-2019 06:44
12-08-2019 12:46
12-08-2019 12:46
What if none of that works?
12-08-2019 13:04
12-08-2019 13:04
12-08-2019 16:43
12-08-2019 16:43
12-09-2019 18:21
12-09-2019 18:21
12-09-2019 18:50
12-09-2019 18:50
I'm on my 4th or 5th Charge 3 now. This last one has a corrupt display with grey and white vertical lines. The prior ones failed differently. Fitbit Customer Service has been excellent--keep sending me replacements when the unit I had fails. (Though the replacement I'm waiting for now has been in transit for 12 days now … they use FedEx Smartpost ground, which is an amazingly slow courier.) I really like the Charge 3, but for the product's lack of longevity.
12-10-2019 01:48 - last edited on 09-06-2020 19:08 by LiliyaFitbit
I sent an email but have not had a reply. Unfortunately I have had the C3 14 months so out of warranty.
Moderator edit: format
